Old 02-17-2011, 11:56 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
WOW I forgot I started this thread my bad guy didnt mean to make people argue so much but i guess its good to get people communicating good or bad lol!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 02-17-2011, 12:50 PM
heffs03mach1's Avatar
heffs03mach1 heffs03mach1 is offline
Vehicle: 2010 dodge ram sport 4x4
Trim Level: sport
Color: blue
Rep:99
heffs03mach1 will become famous soon enough
your alternator doesnt charge as well unless you change the pulley on it, which would explain dimming of lights or poor battery performance. the water pump will need a bigger pulley also to spin it at the same speed it was at so there is less flow involved unless this is addressed. thats about it. this is why when you buy a kit for a car they usually come with all 3 pulleys but i dont know what this one comes with. i am assuming just the crank pulley from the pic and descriptions i have seen.
Old 02-17-2011, 03:40 PM
NashvilleHemi's Avatar
NashvilleHemi NashvilleHemi is offline
Vehicle: 2004 Dodge Ram
Color: Dark Molten Red
Rep:24
NashvilleHemi is on a distinguished road
Man!! I have had the same battery in my Ram since 06 and installed the UD balencer a year ago.. I have ZERO issues with the battery charging... If you put a bigger pully on the water pump would'nt that defeat the purpose!!!
Dynomax cat-back, K&N CAI 77series, AFE TB spacer, Trick Flow 20% underdrive balencer, MSD 8.5 wires, e3 plugs, 3865 Super Chips, Fastmans ported TB, 180 T-Stat
Old 02-17-2011, 04:31 PM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
I'm new to modding so bear with me. Alternator performance should only be affected at low rpm situations ie. idling right? When you are driving it shouldn't make a difference? Sound right guys? Same with water pump or so I would think. Is this what you guys think or am I off base?
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 02-17-2011, 04:50 PM
Trim Level: sport
Color: blue
Rep:99
thats basicaly it. the kits i am familiar with offered these 3 pulleys for that reason. for the trucks i am not sure but i would assume there is going to be some affect given the u/d pulley is normally smaller unless it is exactly the same size as oem. I dont know if it is but maybe someone can enlighten on wether it is the same or smaller.
Old 02-18-2011, 08:21 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
the people that have had battery/alternator problems are guys with monster stereo problems. I don't remember who but one guy even data logged charging voltage before and after his install and there was no change.
Old 02-18-2011, 08:53 PM
Trim Level: sport
Color: blue
Rep:99
well like i said i dont know how these engines react to u/d's but typically those are the problems with u/d pullies
Old 02-18-2011, 09:10 PM
CHVYKLR's Avatar
Rep:252
I know the Ram doesn't have the huge aftermarket support like some other vehicles but the few that I've talked to are doing ok. Like everything else I'm sure there are always your "other" cases that a negative story.
