Old 01-08-2013, 07:03 PM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
fender heights??!!!
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 01-08-2013, 07:33 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
I'm about to go measure. Been a busy weekend. What are yours? And I think I've been slightly rubbing. Rolled my windows down while parking and tried to listen for it
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 01-08-2013, 08:56 PM
Ram725's Avatar
Rep:347
By the way. Went up a curb today and turned on purpose and ate up the bumper. Haha
Build Thread
Old 01-09-2013, 09:46 AM
chadster21's Avatar
Rep:108
hahaha. im at 48 up front and 49.25 rear
Old 01-09-2013, 11:30 AM
Rep:1804
Originally Posted by chadster21 View Post
thats strange...i have the 20x9 -12 off set with same tires and with a 6'' and 1.25'' body lift i rubbed alot... now with adjustables set at 2.75 i sometimes still rub.... whats your fender height
maybe the sport bumper is a bit diff shaped...
I know exactly where you are rubbing. Your tires are grabbing the lower corners of your front valence on your bumper.
Take a dremel and cut off a triangle piece the size of 1" that will rid of the rub.
Its not even at full lock. its about 4/5 of the way and it happens when you swing the tire back to the straight position and grabs the bumper.
Even when trimming you wont even notice it was trimmed.
Do it and you will be ok.
Ill snap a pic later of where I am talking about and how mine looks now after trimming.....I have a -24 offset on 20x10 wheels so I will grab slightly more too
Rep:1804
This is a big truck man!
Old 01-09-2013, 04:30 PM
chadster21's Avatar
Rep:108
yes thats exactly it.... its only on drivers side too
Old 01-09-2013, 04:53 PM
Rep:1804
Its probably both....you just hear it more cause its closer....
take a dremel and cut exactly what I mentioned.
Takes 5-10 mins max and it WILL NOT grab anymore
Old 01-09-2013, 05:13 PM
chadster21's Avatar
Rep:108
il do this for sure when i get home at the end of the month... it goes right thru me
Old 01-09-2013, 05:26 PM
Ram725's Avatar
Rep:347
The rubbing doesnt bother me... I have some clanging noise in the rear when I hit small bumps and its driving me crazy. I've checked all the bolts and they are all tight... I think it might be my tool box or something in it...
Build Thread
lift, setup, tire, wheels
