Old 01-28-2013, 06:17 PM
Originally Posted by Ramadian View Post
ok i checked out Quietpeen....the 33s look niiiiiice!
so my plan is as follows
1. buy 20x10 -24mm and the 35x12.5
my buddy owns the shop im buying them from and is they dont fit he will do a straight exchange for the 33x12.5
win win
There you go man!
You will not lose at all....always great to have a buddy in the business
Whens this happening?
click here --->***Tuner and Muffler Sale*** <---click here
Old 01-28-2013, 10:41 PM
Ramadian's Avatar
Ramadian Ramadian is offline
Vehicle: 2012 Ram 1500 Sport
Rep:17
Ramadian is on a distinguished road
The lift will be within the next couple weeks. rims, tires and flares will happen 1st week of march...
Old 01-29-2013, 10:48 AM
Looking forward to seeing this......
Where are you getting the lift from?
Old 01-29-2013, 11:16 AM
Ramadian's Avatar
Rep:17
well i did some more reading and apparently the Vibrations experienced with the ready lift SST in the 2011s is stil present in the 2012s so im going with the 5100s now, ill be grabbing them from ESSEX distributors in BC unless you know somewhere cheaper..
my mind is still running around my rim options...i am for sure going with the hostage 20s and i for sure am going with the 35x12.5 tires but im still up in the air about the rims width and offset...
i want the tires to match the pocketstyles but also dont want other issues to arise
Old 01-29-2013, 12:39 PM
Keep in mind any leveling kit once it gets to a certain lifting point will create vibration in 4wd from a stop to fast acceleration. That being said, who drives like that.
If going with Bilsteins, I would set them to 2.1 rather than maxing them to minimize this.
Old 01-29-2013, 12:55 PM
Ramadian's Avatar
Rep:17
good to know...
Old 01-29-2013, 02:36 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
^^^^^^^ what fast said!
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 01-29-2013, 03:34 PM
Ramadian's Avatar
Rep:17
with this new knowledge of staying at 2.1 shoul i rethink my tire size?
i looked around a bit
maybe a BFG AT 285/65? (34.5")
any suggestions?
or maybe find a 34"?
Old 01-29-2013, 03:55 PM
Ram725's Avatar
Rep:347
I mean some guys till fit 35". I think you'd be disappointed with 285s... At least I always have been.
Build Thread
Old 01-29-2013, 04:00 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
any suggestions?
I am planning on doing the same once my ordered 2013 comes in...post some photos up if you don't mind once done.
Also - from what I have seen MOST of the manuf of the 2" leveling kits say you can run a 35" tire fine...so I would think with the Bilstein 5100 setup at 2.1" you would also be ok with a 35.
The BFG AT is a great tire, the 285/65/20 is 11.5" wide so *might* not need a wheel spacer or offset wheel - should be able to just put em on stock 20x9s and go. Which is why I am considering them...wider than stock but not too wide to where I need a spacer. Height according to the BFG site is 34.7" - so thinking the stocker is 33" tall, makes this one 1.7" taller so .85" closer to the fender...again should be ok under 2" - not sure what the height difference is but my 07 has only 2" level and have had 35s on it for 5 years. A TRUE 35" tire (Toyo MT 35x12.50) rubbed pretty bad near lock on both sides and also the side wall would rub in the rear when turning onto an incline and truck flexed a bit even with 1/4" wheel spacers on the stock 20s. BUT since then I have ran 2 sets of Toyo ATs that are 34.5" tall and love them! Full lock with some compression may get a LITTLE rub but no big deal. But these DO need 1/4" wheel spacers or I think -12 offset wheel to fit.
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
lift, setup, tire, wheels
