Old 04-28-2014, 07:50 PM
astra9 astra9 is offline
Vehicle: 2014 Ram 1500
Trim Level: Outdoorsman
Color: Bright Silver Metallic/ Black
astra9 is on a distinguished road
wrong spot
Old 05-09-2014, 08:12 PM
Coastie89 Coastie89 is offline
Vehicle: 2013 Dodge Ram
Trim Level: SLT/Big Horn
Rep:32
Coastie89 is on a distinguished road
Finally figure how to load pics, this was done about 6 months ago.
Last edited by Coastie89; 05-09-2014 at 08:13 PM. Reason: 2" Hell Bent Level Kit / Debadged
Old 06-07-2014, 12:32 PM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:34
draken is on a distinguished road
So i have been reading through this thread and i have a couple of questions. i am planning on getting a 6 inch zone lift with the 5 inch rear and bilstein 5100's set at 2.1 to level out the front. I was wondering whats the best size tire for that lift, i have 3.55 gears 5.7 hemi with the diablo and custom hemi tune. i want to run 37's because i am afraid of the 35's looking to small.. I had a 4 inch lift on my lat 07 ram with bilsteins all around and i felt like 35's fit that perfectly.. Is there really that much power loss with 37's? also how is gas mileage with both sizes of tires?
Zone 6" with 5" rear, Bilstein 5100s, Toyo M/T 315/70/18, 18x10 MotoMetal 967s, Bushwacker Pocket Flares, S&B CAI, Flowmaster 10 series, Diablo Trinity With Hemifever Tune, Drop in K&N Filter, Retrofitted headlights, 5k morimoto HID, 6k Fogs, Metal Tonneau Cover, Plastidipped Bumpers and Grille
Old 06-08-2014, 09:20 PM
RamSpur RamSpur is offline
Vehicle: 2012 dodge ram
Color: silver
RamSpur is on a distinguished road
Old 06-09-2014, 11:59 AM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2051
I would run the Bilsteins at 1.4" to level out the lift. 2.1" will make it look nose high without doing a rear spacer. With that size lift you can get away with 35's but they do look a little on the small side. I had that setup on my 1500 which can be seen HERE. You can definitely go with 37's as well though. With 3.55 gears you're definitely going to notice them but the truck will still be drivable and you'll get used to it.
Old 06-09-2014, 12:40 PM
draken's Avatar
Rep:34
Thanks for the reply! Just curious do you know how much of a difference in gas mileage with 35's versus 37's?
Old 06-09-2014, 12:52 PM
Rep:2051
A lot of that comes down to how you drive the truck and where the majority of your driving is. I would say the difference would be about 1 mpg max.
Old 06-09-2014, 07:52 PM
draken's Avatar
Rep:34
Originally Posted by RamSpur View Post
Whats your set up? Nice looking ram.
Thanks for you help man i appreciate it.
Old 06-09-2014, 11:52 PM
Smokinjoe1969 Smokinjoe1969 is offline
Vehicle: 2006 dodge ram mega cab diesel
Smokinjoe1969 is on a distinguished road
Default Big Red
2006 dodge ram 2500 mega cab. 2 inch shock tower spacer in front and 2 inch block lift in back. 35 in Kumho M/T running sweet. Getting ready to move up to 37s.
Old 06-10-2014, 04:59 PM
Rep:1804
Id like to add to this....its drivable but not bare able. Trust me! I ran ran on 37's for 2-3 weeks before I was 1) going to sell my truck 2) blow up my truck...lol 3) do 4.56 gears
I opted for option 3 and was the first to have this done.
If you have 3.55, I would not suggest this.
Mind you, I did not have an option then to run a tuner with custom tune, BUT i did calibrate my speedo.
Truck has ZERO balls from start to go and driving up hills, it will hunt and hunt and hunt for gears.
Again, I did not try with a tuner, Im sure it will help a bit, but you'll only be masking the issue.
Id say if you want to run 37's, expect the worst and if it appears not to be bad, well then you are set.
I just could not live with it like that
lift, setup, tire, wheels
