Old 07-27-2014, 07:16 PM
ncrohr ncrohr is offline
Vehicle: 2014 Ram 1500
Trim Level: Tradesman
ncrohr is on a distinguished road
Ok guys, I've read through a thousand posts trying to figure out the best route to take. I initially wanted to level my 2014 Tradesman with the readylift 2.5" front 1.5" rear until I found out about all the issues with the ball joints. Now I'm considering doing a 4" lift kit instead. Is there anyone running a 4" lift on their 2014? If so, is there a recommended brand to go with? Will I still need to replace the UCA's with a lift instead of a level? And finally, a dumb question, but I see a lot of guys running the 5100's with their lift kits. Is this a necessity or will the lift kit lift and level out my truck? Sorry if I sound arrogant, this is my first brand new truck and first time modding a truck from a clean slate.
Old 07-27-2014, 08:41 PM
crazyZ33's Avatar
crazyZ33 crazyZ33 is offline
Vehicle: 2014 Dodge Ram Sport
crazyZ33 is on a distinguished road
Default My 2014 Ram 1500 sport
will take more pictures when it'll stop raining outside!
Enjoy
4'' BDS suspension
Black Rockstar 2 20x9 -12 offset
325/60/20 Duratracs
Bushwacker pocket style
parked with a lifted outdoorsman with 35x12.50
Old 07-27-2014, 08:54 PM
Oh wow...That's a gorgeous truck!
Old 07-27-2014, 09:57 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Trim Level: Express RC
Color: Black Express Package
Rep:67
Nice truck. I had the duratracs on my 13 and wanted another set the same size as yours for my lifted 14 but they were a little more cash than I had left when I was done.
Old 07-28-2014, 07:54 AM
crazyZ33's Avatar
I found them expensive too but up here in Quebec, tires need the snowflake logo on them for winter usage, otherwise you're illegal. That narrowed my choices to the Duratrac's since they are the only one with this logo...
Old 07-28-2014, 02:50 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
Originally Posted by Shidso View Post
Hey guys. New to the forum today. I recently had an 08 ram 1500 with level kit and was running 305-55-20 Nitto Trail Grapplers on Helo 20" rims with +18 offset. There was very minor rubbing while turning on the upper control arm. Not enough to cause shredding of the inner sidewall tread of the tire. I traded yesterday for a 13 Ram 1500 and am curious if I install a leveling kit can fit my aftermarket rim/tire combo with minimal rubbing? I am sure this question or similar has been asked before but I didnt search the entire 66 pages. Any information from real world experience would be great! Thanks
You'll have the same issue with the rubbing on the upper A-arm. Possibly a little worse depending on how the truck was built. 1/4" wheel spacers will take care of that though.
You probably wouldn't have any issue with ball joints popping if you level. Very few do... If you want to go with a full 4" lift check out Zone Offroad or BDS. Both make quality lifts.
The Bilstein 5100's are added to level the lift fully. Most lift kits will get rid of a certain amount of rake but not all of it. The adjustability of the 5100's allows you to get rid of it fully.
Old 08-12-2014, 09:18 PM
jlambe67 jlambe67 is offline
Vehicle: 2012 Ram1500 Quadcab
Trim Level: Express ST
Color: Dark Blue
jlambe67 is on a distinguished road
Just ordered 20x9 chrome fuel hostage -12 with 33x12.5x20 federal mts already have it ready lifted with 2.5/1.5 can't wait to get them pics to come
Old 08-27-2014, 04:53 PM
Apacheav8tr Apacheav8tr is offline
Vehicle: 2012 Ram 1500
Trim Level: Limited
Apacheav8tr is on a distinguished road
Ok guys so here it is guys. I have a 2012 Ram Limited 4x4 and I wanna run a set of fuel mavericks 22x10 with a -24 offset and 5" back spacing on toyo m/t 37x13.5x22. Can I run these with only installing the BDS 6" coil over suspension with the fox shocks or will I have to add a body lift as well? Because I would like to stay away from a body lift. Thanks
Old 08-27-2014, 04:59 PM
Rep:2036
You'll need to have the coilovers cranked and even at that you'll still rub. Trimming will be required for sure but you can make it work.
Old 08-27-2014, 06:13 PM
fastNugly @ BP fastNugly @ BP is online now
Brandon addressed it.
10" with -24 offset is actually 4.5" backspace, but thats neither here or there.
You will have to crank the coilovers up. Possibly not to the max, and it will fit.
If you have the plastic bumpers, you will have to trim the lower valence. Not much.
But since you have coilovers, it will give you the ability to play with height to get it to where you want, but you will be ok.
If you need pricing on lift and wheels, let me know
lift, setup, tire, wheels
