Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 01-06-2011, 09:26 PM
ssellars ssellars is offline
Vehicle: 2011 dodge ram
Trim Level: sport
ssellars is on a distinguished road
Default Hid install 4 headlight system
Ok i have installed a few sets of HID's in the past with no trouble at all. But it seems Dodge Ram is the first to stump me. These are for my own truck, a 2011 Dodge Ram 1500 sport with the 4 headlamp system. I purchased an H11 kit for the lows, 9005 for the Hi's and the same for the fogs I believe. Attempted the lows and nothing, switched plugs around etc. no results. I have read other forums on here and really didnt understand quite what i need to do. Also am i going to have the same problems with hi's and fogs. The DRL's appear to run off the highs. If some could please help me i would greatly appreciate it.
Old 01-07-2011, 01:59 PM
Rep:3322
The DRLs will cause you issues unless you get a DRL rectifier, I know oracle has a kit. Are you just plugging them into the factory harness? If so, the dodge electrical system is whacked, literally, so you need to run HIDs off of relay harnesses with the MIL cancellers (basically a resistor in the stock harness). You shouldn't have any issue with the fogs though, I've never had any with them on the installs I've done or helped with.
The relay harness is dead simple to install and couple that with the cancellers, you're looking at a quick job to get it all together.
And finally, welcome to the Z, don't forget to stop by the newbie section to get the official welcome.
Old 01-08-2011, 09:06 AM
boosted20v boosted20v is offline
Rep:93
boosted20v will become famous soon enough
Send a message via Yahoo to boosted20v
What kit did you go with? You need H10's for your fogs not the 9005's. Relay harness for the low's, fogs are straight plug and play. Can't help you on the hi's as I didn't do them.
Old 01-14-2011, 12:58 PM
Trim Level: sport
My fogs are 9145 which i am told is 9005? Can i buy a relay harness anywhere, or is it specific for Hid's? Also can u give a brief explanation of the procedure to connect it?
Old 01-14-2011, 01:00 PM
Trim Level: sport
Thanks for the welcome, and my drl's run off my hi's!!!
Old 01-15-2011, 10:52 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
The plugs may be the same/similar but the wattage is too high for fogs (I think). 9145's swap with H10's, I believe.
Old 01-17-2011, 11:42 AM
Trim Level: sport
Can anyone help with the relay harness install?
Old 01-17-2011, 11:50 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Here's my relay install in my 2010
http://ramforumz.com/showthread.php?t=70224
Old 01-17-2011, 12:32 PM
Trim Level: sport
Thanks for the help. I also found a link to an install video. Got my relay harness on the way. I will post picks of my install when i recieve it.
Heres the link.
Old 01-18-2011, 10:39 PM
Crash Crash is offline
Vehicle: 2016 Laramie Longhorn Limited
Trim Level: Laramie limited
Color: Black crystal pearl
Rep:404
My 2010 had 9145s in the fogs i upgraded to 9005s when i went hid they work perfect and no heat issues. I cannot help with your hi beams as i did not do mine....yet but i want to. I have heard about kits to avoid drl problems but have not seem one that works yet. If someone has done it successfully tell us what we need and where to get it please
