Old 01-07-2011, 09:48 AM
sensor5 sensor5 is offline
Vehicle: 2011 Dodge Ram QC 4x4
Color: Blue
Rep:13
sensor5 is on a distinguished road
Default 3.55 to 3.92
I recently bought a 2011 Ram 4x4 w/ 3.55 rear end . I installed 33" tires and will be towing my bass boat. I am not happy with 3.55 gears and looking to change to 3.92s. It is a lot cheaper to have 4 Wheel Parts or a private mechanic here in Indianapolis install the 3.92s compared to my dealer. However, I'm worried about warranty issues. Is it a bad idea not to use a dealership?
Old 01-07-2011, 10:04 AM
iRESQu iRESQu is offline
Rep:2217
Yes, it would probably be less costly to have a private mechanic install the 3.92 gears, but it would not be a bad idea to have the dealership install them for warranty reasons. Your fuel consumption will go do with the 3.92 gearing.
Old 01-07-2011, 11:52 AM
Terrence's Avatar
Terrence Terrence is offline
Vehicle: 2013 Dodge Ram 1500 RCSB
Rep:57
Terrence will become famous soon enough
i know i have an older model truck but my truck came with 3.92s and in town i only get about 12 mpg but i really like them
Old 01-07-2011, 02:12 PM
BRYFRY BRYFRY is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport Crew Cab 4x4
Color: Inferno Red
Rep:32
BRYFRY is on a distinguished road
Where can someone get a good deal on the 3:92 gears?
Do you have to get a whole new rear assembly, or can you just swap out gears??
-sorry for my ignorance!
Old 01-07-2011, 03:41 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
The mpg change from 3.55 to 3.92 won't be huge but there will be some. Remember both front and rears have to be done. As for the warranty issue, I really can't say if having the 4x4 shop do it will be a problem but it does leave a window open for Dodge to deny a claim if something were to happen.
Before you change the gears I suggest you use the Body Builder's guide to make sure you are setting your Ram up for what you need. Go to http://www.dodge.com click on "owners" then "body builder's guide".
Brian:
Old 01-07-2011, 03:42 PM
Color: RootBeer
Rep:1287
No reason to be sorry. It is just the gears. As the original post said the local 4x4 shop will likely be cheaper than the dealer.
Brian:
Old 01-09-2011, 11:17 PM
ScatPak07's Avatar
Rep:970
You should go with some 4.10 gears if your going to spend the money. You wont notice that much of a difference going up to the 3.92s, but with the 4.10s you should.
Old 01-09-2011, 11:23 PM
I agree with Scat . Theres not enough difference there for me to worry about going to 3.92 . I have 4.10's in my truck from the factory with 33" tall tires .
Old 01-10-2011, 11:10 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
+1....Going to 4.10 when i do 35s.
[CENTER][SIGPIC][/SIGPIC]
Old 01-10-2011, 11:22 PM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
definitly go to 4.10's if you keep the truck for a while you may want bigger tires and you only want to change gears once. as far as warranty, it's only the bearings and gears in the rear end you'll be losing warranty on that's no big deal.
Too many mods to fit here!
