Old 01-07-2011, 03:08 PM
mowery33 mowery33 is offline
Vehicle: 1998 Dodge Ram
mowery33 is on a distinguished road
Default Torque Specs
Sorry, I'm in a hurry and am getting different answers as to the torque specs. I need to know the torque specs for 98 ram 5.9 rocker arms and intake manifold, and anything else that is related to changing a plenum gasket, please.
I really appreciate you guys, thanks
Old 01-07-2011, 03:22 PM
Rep:1885
http://www.ramforumz.com/showthread.php?t=47741
Old 01-07-2011, 03:31 PM
Thanks for the help, now what about the rocker arms? I need to know the torque specs for those.
Old 01-07-2011, 03:33 PM
Rep:1885
Working on that one. Be just a a minute.
Old 01-07-2011, 03:34 PM
Rep:1885
Rockers torque to 21 ft. lbs
Old 01-07-2011, 03:38 PM
Thanks soooo much! I'm a teacher and am about to get off of work and i will not have access to the internet until Monday. I'm replacing the plenum gasket this weekend, so it's nice to get that info before I leave, thank you
Old 01-07-2011, 03:40 PM
So the plenum pan is 12 ft lbs, right?
Old 01-07-2011, 03:47 PM
One more thing...would not tightening the rocker arm bolts enough cause a tapping, or knocking noise while running the engine?
Old 01-07-2011, 04:04 PM
Rep:1885
No, that's for the manifold bolts themselves. The pan tightens to 7 ft. lbs. or 84 in. lbs. A loose rocker could cause a noise but it would have to be loose enough to back off. A collapsed/failed lifter is more likely.
