Old 01-08-2011, 06:27 PM
pbdupre pbdupre is offline
Vehicle: 1999 Dodge Ram
Color: Green(top)/Silver(bottom)
pbdupre is on a distinguished road
Default Fan pulley not aligned
Hey, I am wondering if I have moved the pulley that holds my engine cooling fan. It is out of alignment of the other pulleys and the serpentine belt is hanging off the engine side of the pulley about 1/4 of an inch.
I just replaced the fan clutch today and did not put a wrench on anything other than the tensioner and the big bolt between the fan and the pulley.
When I screwed the fan back onto the pulley I turned the pulley instead of the fan as that was a lot easier to get it screwed back in. Could I have moved this pulley doing any part of this repair?
1999 Dodge Ram 1500, 2wd, 5.2L
Old 01-08-2011, 07:34 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
For some risen the pulley sounds like it is not seating against the water pump. Was there a bushing in the end of the new clutch that don't need to be there.
MagnaFlow
Airaid Jr Kit
D/S Predator
Amsoil
Old 01-15-2011, 09:47 PM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
How new is the pump? Have you checked to see if the water pump shaft has play?
Old 01-15-2011, 11:08 PM
The pulley is part of the water pump and is preset . Are you sure the belt is on the crank pulley all the way ?
