Old 01-09-2011, 09:00 PM
bcjjones bcjjones is offline
Gender: Not Specified
Rep:13
bcjjones is on a distinguished road
Default Kegger
Was thinking about doing the kegger mod to my 1996 non egr 318, but i had read somewhere that the newer models already have the "runners" taking off from the factory. Which from what i understand is all the kegger mod is, removing the runners. So if I'm correct that the newer models already have this done, can I just take one from a newer 318 with the runners already removed from the factory and install it with the same affects as the kegger mod?
Old 01-10-2011, 07:36 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
what are the runners, n where?
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 01-10-2011, 08:25 AM
"kegger" mod??? I've never heard of that. Care to enlighten us?
Old 01-14-2011, 01:54 AM
Deleted09's Avatar
Deleted09 Deleted09 is offline
Vehicle: 2009 Dodge Ram
Trim Level: Base
Color: Sandstone
Rep:13
Deleted09 is on a distinguished road
The Kegger, or intake manifold, it looks round like a keg, can be ported and modified inside. You will need to take the manifold off if you are fixing a plenum gasket leak. Any of these engines that I have looked at have some plenum leak. Just take the throttle body off, and look in with a flashlight, if you see streaks of oil in the pan, the gasket is leaking, and you are getting oil into the intake, and burning it in the engine.
While you are looking in there, you can see if there is a divider, seperating the manifold in two, or a one piece plenum. The original design on older trucks has the divider, and newer ones don't have the divider, and more top end power. The runners where never removed, but the divider can be removed from an older model, or just switch to a newer manifold without the divider. Just use a vice grip and chip out pieces, it is very brittle and will break out easily.
Old 01-14-2011, 09:41 AM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I have a how-to in a PDF just send me a PM with your email
Old 01-18-2011, 07:46 AM
98redbull2's Avatar
Rep:52
i just figured out why my brother had to put oil in his truck pretty often, bad plenum gasket so maybe this weekend when we fix it i might try the mod for em help turn them big 20 inch forteza rims hes got on there lol
