Big-3 upgrade - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-09-2011, 11:55 PM
Rep:3347
Default Big-3 upgrade
With the power demands I'll be looking at, I'm contemplating the big 3 upgrade, and came across this site http://dynamicgrounding.com/ on another fo-*cough*-um. The guys have been quite happy with the product, but what do you think. It's mostly just grounding, but 4AWG to both heads with 2AWG from the battery to the frame all for $77. Would this be a good/simple way to do the upgrade, or should I just do it my self with cable from the local Acklands?
What do I really need to upgrade? Do I need to up the grounding from the heads as well, or just the alt - +ve, +ve - fuse box, and -ve to frame?
Old 01-10-2011, 12:08 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
More grounding doesn't hurt, but it doesn't do much either.
The alternator is gonna send what it's rated for, and no more, and your stock wiring is plenty for that current.
Kinda liike a pipeline...compressor pushes "X" gallons per minute through say a 24" line. You change the line to a 36", the compressor is still pushing "X" gallons per minute.
As long as you have good grounds and a strong battery, that is all you need..
Old 01-10-2011, 12:32 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
As far as i've read you want to upgrade the + from the alt to the battery, the - from the engine block to the battery, and the - from the battery to the stock ground, usually somewhere on the fender.
Carven exhaust, K&N CAI, Leveled with wheels and tires, Sundown & Skar audio.
Old 01-10-2011, 07:59 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Agreed. If anything start with the battery, then go from there. That $77 kit looks like one of the biggest scams I've seen since the "Solar powered clothes dryer" days.
Are they actually claiming that a Big three upgrade will give you more HP and Torque? Wow... Just wow.
Old 01-10-2011, 10:03 AM
Rep:3347
But, with a larger pipe diameter you reduce flow restriction, the point that you stop is when you have to compare cost vs flow potential. A similar comparison id pushing the same volume through a garden hose compared to a fire hose.
Anyhow, with pushing close to 100A in audio alone, would upgrading the vehicle's power cables be something I should do, or only if I notice some dimming issues.
Lol, I was ignoring the gains in HP and MPG, I called BS the minute I saw that. But the guys that have done this upgrade have claimed faster start ups on stroked motors, less dimming of lights, and a more constant bass note. And as a side not, these guys that are reviewing aren't newbies, so i do kinda believe them.
Old 01-10-2011, 10:48 AM
Trim Level: Custom
Rep:1648
As for that analogy, yes......But the pipe you already have is bigger than required for that flow....There is no restriction currently.
Don't let the 100amps distract you, you probably will never pull that...EVER.
Mine is rated 150 main, 60 and 80 on fuse distro.....I am running 3 amps that arent as efficient as your HD's. You are fine...
Old 01-10-2011, 11:04 AM
Rep:3347
Alrighty then. can you tell I'm an audio newb? I really do hope to make Gatty, just so you can see how badly I butchered this job
Old 01-10-2011, 11:12 AM
chithead's Avatar
Rep:2078
You gonna make a detour over to my neck of the woods so I can check it out too?
Old 01-10-2011, 11:14 AM
Trim Level: Custom
Rep:1648
How will ya know if ya don't ask....
Old 01-10-2011, 11:18 AM
Rep:3347
I think my biggest problem is that I know enough to get myself into a lot of trouble, but not enough to get out of it. Now I just need to find someone that's not tone deaf to do the tuning on it.
