2010 RAM TPMS module - where?
22K views 2 replies 3 participants last post by  holydiver89
#1 ·
Hi everybody,
I have a 2010 RAM SLT that I bought with a salvage title and I am fixing up. The only remaining issue is with the TPMS - I only have a service manual for an -09 and it seems that the -10 model has a different system.
Does anybody know where the TPMS module for a 2010 is located?
Bo
#2 ·
REMOVAL
NOTE: The TPM is located in the left front wheel well forward of the splash shield, near the body to frame mount and is mounted to the frame with a bracket.
1.Disconnect and isolate the battery negative cable.
2.Raise and support the vehicle.
3.Disconnect the wiring harness connector (2) and wiring harness retainer (1) at the Tire Pressure Module (3).
4.Remove mounting nut (4), then remove the Tire Pressure Module (3) from the frame.
