Leveling Kit/Death Wobble Poll - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Forum Polls!
View Poll Results: Did you add a leveling kit and get the death wobble?
Yes - with an alignment. 11 22.45%
Yes - without an alignment. 1 2.04%
No - with an alignment. 30 61.22%
No - without an alignment. 7 14.29%
Voters: 49. You may not vote on this poll
Old 11-16-2012, 09:57 AM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
I haven't had a death wobble and I did my leveling kit 3 weeks ago and still haven't gotten an alignment...
Old 04-26-2013, 07:10 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
Originally Posted by Pull Ya View Post
"Real" death wobble can be caused by numerous problems--tires, wheels, tie rods, ball joints, steering stablizer, etc etc etc. In my research there is no one common cause and no one common cure. What might cause mine may not effect your truck and what cures yours might not cure my problem. My recommendation would be to check all the front end parts to see if they are all within specs and then check your wheels and tires, including tire pressure. Your truck should have the new style tie rod kit already installed although there has been some problems even with the new tie rod kit. There is a TSB about "Death Wobble". If someone tells you that they have found one single cure for all death wobble I'd recommend you get another opinion cause it just ain't true. Make sure whatever you do cures the problem, and does not just mask it.
Jay
I agree ^^^ I had an issue like/similar to Death Wobble but I had the front end replaced with a 3500 Ram... and I have NO lift kit just a 2" spacer in the front to level out the truck...
Smile even if its a little creepy
Old 04-26-2013, 11:28 PM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:67
steveschaedel will become famous soon enough
I had the Truxx 2" leveling kit on my 2006 2500 4x4 for years - did lots of off road stuff but never had to pee myself :-) No death wobble or anything like that - I did have the alignemnt done when they were installed and thats it.
Old 05-14-2014, 11:51 AM
HandyDandy HandyDandy is offline
Vehicle: 2004 Dodge Ram 2500
Color: Blue / Silver
HandyDandy is on a distinguished road
I am surprised not to see more posts on this topic? I have a 2004 ram 2500 with the Hemi. The suspension is stock no lift or leveling kits installed. The truck only has 74K miles on it. I have replaced the original tires at around 60k with a set of BFG all terrain tires that are a little lager then the original but not much. I had a slight vibration at high speed when you hit a bump in the road or more frequent passing over a bridge. I took it to a local shop as the truck is out of warranty now and they did an front end alignment to factory specs. Now I have the death wobble? I had a similar experience when the truck was only a year old and I took it to the dealer and they replaced almost every front end part there is to replace about $2800.00? But it was under warranty at the time. I thought at that time that it was strange so much could have been wrong with the front end with so few miles less then 20K at the time. But now that the wobble is back I am seeing much posted on the World Wide Web about this Wobble and I need to fix it yet again. All front end parts seem to be in good working order and the steering box only has a slight or minimal play or movement. Any recommendations would be helpful. Thank you
Old 09-12-2014, 12:50 AM
metalman1980's Avatar
metalman1980 metalman1980 is offline
Vehicle: 2004 Ram 1500 Laramie 2wd
Color: Atlantic Blue
metalman1980 is on a distinguished road
I've got a 2004 2WD 1500 with a 3" supreme suspensions (top gun customs) leveling kit with the longer procomp shocks and have no vibration issues.
