Old 01-10-2011, 02:42 PM
Big Ed Big Ed is offline
Vehicle: 2010 Ram 2500
Big Ed is on a distinguished road
Default 5w20 vs. 5w30 oil in Ram 2500
I have a 2010 Ram 2500 with the 5.7 Hemi. In my owners manual it states that you can use 5w30 oil in place of the 5w20 if your GCVWR exceeds 14,000 lbs. Now on occasion I do exceed that weight when I tow my boat however most of the time I run below the 14,000 GCVWR.
Now why would Chrysler give that option to run 5w30 to the Heavy Duty crowd? I know the 5w20 is spec'ed for the MDS Hemi and most likely for the Heavy Duty's to meet better fuel mileage requirements but I'm wondering if given the option is 5w30 a better choice.
2010 Dodge Ram 2500, Laramie,Crew Cab,Hemi,4X4.
Old 01-10-2011, 03:21 PM
Rep:1909
Most likely because of the loads placed on the engine.
Old 01-10-2011, 03:33 PM
Burkdadhemi's Avatar
Burkdadhemi Burkdadhemi is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Rep:100
Burkdadhemi will become famous soon enoughBurkdadhemi will become famous soon enough
I believe it also has to do with the temp in your area, there should be a graph in your Manuel with temp ranges, I ran 10w-30 in my 03 5.7.
MagnaFlow
Airaid Jr Kit
Royal Purple
Old 01-10-2011, 03:55 PM
I agree RamTech with the heavier loads needing a thicker viscosity to protect the engine. Burkdahemi, as for a graph in my owners manual that is a negative. The owners manual spec's 5w20 as does the oil fill cap on the engine. However, their is an option to run 5w30 when operating under the aformentioned 14,000lb GCVWR. My question is fuel mileage and MDS aside (which I'm sure is behind the 5w20 spec for many of todays vehicles) is 5w30 a better choice. Obviously if your going to work the truck hard Chrysler seems to think so.
Old 01-10-2011, 04:10 PM
Rep:2657
the 5W-20 just makes the Hemi with MDS work efficiently
I bet if you look at your oil fill cap on the 2500 models, it will read 5W-30 or 10W-30
many vehicle companies & ALL government agencies, use the weight standard not as what you use the vehicle for, they use the standard as to what the vehicle is capable of
Old 01-10-2011, 04:42 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
If your worried about durability with the 5W20, don't. I've run 5W20 for 203,000 severe miles in my Sidewinder cammed 05 Dodge Magnum, spraying a 100 shot on the weekends, towing heavy trailers often during the week. I use either Mobil 1, Castrol Syntec or Penzoil Platinum on 5,000 mile changes, same deal with my 05 1500 QC4X4 Ram with 140,000 miles. Yes, I race it also and spray a 100 shot and it has the race cam as well. Neither use any oil, the old oil is still nice looking when I change. If the thin oil saves you gas, why not use it? These motors have very tight tolerances.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 220,000 miles To Hell and back. 14.2/96 mph NEDW
Old 01-10-2011, 05:40 PM
jdanthony26's Avatar
jdanthony26 jdanthony26 is offline
Vehicle: 2010 Dodge Ram 2500 4x4 CC
Trim Level: Big Horn Crew Cab
Rep:38
jdanthony26 is on a distinguished road
Hey all,, i have used 5w20 all the time,, they told me to do the 5w30 and i had nothing but problems with check engine lights and bogging, i changed it back in 2 days and everything was fine
Old 01-10-2011, 07:32 PM
Thanks guy's, I guess I'll run the 5w20.
Old 01-10-2011, 10:17 PM
ttontis's Avatar
ttontis ttontis is offline
Trim Level: TRX Crew
ttontis is on a distinguished road
Big Ed I run 5w30 in my 2010 2500, and oil filler cap states 5w20 but owner’s manual says you CAN run 5w30 in the 2500. It is due to the extra work load put on the engine from towing and general working environment.
Old 01-11-2011, 08:37 PM
Good to hear from another 2500 owner. I'm really on the fence with this. I've been running Mobil1 5w30 and it's convenient since thats what I use in my wifes Chevy Tahoe. However, I wondered if 5w20 is really better for the Hemi. Some people say it's only so the MDS work properly and to improve fuel mileage. Others claim the Hemi has tight tolerances within the engine and 5w30 may not lubricate as well. Yet Dodge spec's the 5w30 for heavy hauling so that may be considered contrary to the "tight tolerance" theory.
Bottom line is I alway's run synthetic and 5w30 is what all the other vehicles in the stable use so I may just keep running the 5w30.
My next debate is whether the new Castrol Edge is worth switching too.
