Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Recalls and TSB's.
Old 01-12-2011, 03:34 PM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
THAT IS INSANE
thank god i did mine ASAP it was like a 30 minute job but well worth it dont need no issues like this
Old 01-12-2011, 04:18 PM
papasmurfor9 papasmurfor9 is offline
Vehicle: 2011 Dodge Ram Laramie 4x4
papasmurfor9 is on a distinguished road
I have not had an issue. I was at the dealer for another problem and they told me about the recall.
Old 01-12-2011, 04:38 PM
Rep:82
what problem did you have
Old 01-12-2011, 06:16 PM
Clumsy Clumsy is offline
Vehicle: 2011 dodge ram 1500
Trim Level: sport
Clumsy is on a distinguished road
Default Oops
Originally Posted by E220 View Post
hey guys I just came from my dodge dealership
Take your 2011 1500 Rams in for them to inspect the rear axel fluid and to get it topped up
Mine was beyong adding fluid... got a new rear end. It was the second one that totaly failled at theat dealer.
Beware that if you were running for some time low on lubricant or no additive in your rear end, adding fluid will only delay the failure of the rear end...
Mine failled at 1500 KM the other in the yard failled at 1000 KM.
Old 01-12-2011, 06:25 PM
Rep:82
I have 1400 km now. Should I be concerned
Old 01-13-2011, 08:59 AM
Trim Level: sport
Depending if your Doge ram 1500 is one that was missing fluid from the assembly line, 1000 KM is sufficient to cause failure in certain condition. Mine was driven in northern Alberta, and started grinding at around 1000 KM and failed at 1400 KM in mid December. The logic is that if the dealer would have top up the fluid right away instead of waiting for the appointment that he given to me ( a week later), the differential would not have failed right away, but some wear would have been present ( grinding sound). How that would affect the smooth operation of the differential? or it's future failure? In your case, I would get it checked asap, and keep record if they had to add fluid or not, for future reference. The fact that they have to add a additive, is not reassuring to me, but it to soon to know if this rear end problem, will be a chronic one.
Old 01-13-2011, 09:01 AM
Rep:82
Yeah Well mine was not making a grinding sound or any sound for that matter , I found out about the recall and made an appointment right away and its seems to be driving the exact same way. I have the receipt and I keep that all in a file folder at home.
Old 01-27-2011, 08:11 PM
mrroader14 mrroader14 is offline
Trim Level: outdoorsman
Color: deep water blue
mrroader14 is on a distinguished road
got my new truck last week, and the dealer info sheet for 2 trucks i was looking at showed that they are taking care of this issue before new ones leave the dealer
Old 01-27-2011, 08:47 PM
11RAM's Avatar
11RAM 11RAM is offline
Vehicle: 2011 Dodge ram 1500 Quad Cab
Trim Level: SLT Big horn 4x4
Color: Brilliant Black Crystal Preal Coat
11RAM is on a distinguished road
I have an appointment for second oil change (3,000 miles) next week and will be sure to ask about this. Thanks for the heads up.
Rough Country level kit, 35x12.50x20 General Grabber, Airaid CAI, Magnaflow muffler.
Old 02-01-2011, 11:54 PM
James.Tomlinson James.Tomlinson is offline
Vehicle: 2011 Dodge Ram 4x4 Crew Cab
James.Tomlinson is on a distinguished road
So if my truck was built Jan 20th would there not even be a problem anymore? Would all the new trucks be corrected? I heard the problem was that the hole was too low and you had to over fill the rear diff...Maybe I am wrong. I just hope if that is the case in all the new trucks they build the have the hole in the proper place.
