Old 01-11-2011, 09:23 AM
JaredConspiracy's Avatar
JaredConspiracy JaredConspiracy is offline
Rep:243
JaredConspiracy has a spectacular aura aboutJaredConspiracy has a spectacular aura aboutJaredConspiracy has a spectacular aura about
Default headlight baking help
im in the process of doing mine but i need help figuring out how to remove all of the leftover sealant off of the lenses...its so tough! how'd yall do it?
Old 01-11-2011, 10:19 AM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
What's "headlight baking"? Is that like cooking them till they turn dark?
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 01-11-2011, 10:26 AM
Rep:243
its cooking them in the oven until the come apart so the components on the inside can be custom painted and you can also put custom lighting or whatever other knick knacks you'd like to put into your headlights. It's basically the gateway to making custom headlights out of your stock ones.
Old 01-11-2011, 10:37 AM
Rep:243
for example...
These are the backs...
here are my lenses...
and finally the headlight housings...
Old 01-11-2011, 11:22 AM
saunders1986 saunders1986 is offline
Color: Inferno Red
Rep:78
saunders1986 will become famous soon enough
you dont remove it, after ur done painting, put em back together, heat them up again, and squeeze them together tightly, reuse the sealant
Old 01-11-2011, 11:37 AM
CapperRAM's Avatar
CapperRAM CapperRAM is offline
Vehicle: 2013 RAM Power Wagon
Trim Level: Power Wagon
Rep:205
CapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura about
^^^^ What he said...!!!
Old 01-11-2011, 01:26 PM
Rep:243
really!? well too late for that. im working with an old AAC tech and he suggested removing it because that sealant is more like plastic weld and it normally doesnt react to that well...i plan on putting all new silicone in the channel.
Old 01-11-2011, 01:43 PM
I push the skinny pedal
Rep:3283
I had to warm mine up a couple of times, but not like when I baked them open. Just kept them warm, so 5 min at 250F and I acutally used a flat blade screw driver to scrape the sealant out. Then I used a clear sealant. Don't use another color cuz it'll show when it squeezes out.
Kurtis
Old 01-11-2011, 06:36 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
I agree with the others that you should have left the sealant alone. Second mistake was to paint them before removing it. Only thing I can think is strong enough to remove it would be Carb cleaner or brake cleaner, so your paint job will get all screwed up. I'd say if you can't make it work get a new pair and start over.
www.beatcraigslist.com - for posting dangers & secrets
Old 01-11-2011, 10:47 PM
Rep:243
like i said. i had a former AAC tech help me with these and he did headlights for five years. Everything ended up being just fine!
