Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Rust Repair
Rust Repair Fighting Mother Nature!
Old 01-13-2011, 04:22 AM
Marcus Marcus is offline
Vehicle: ram 1500
Marcus is on a distinguished road
quick googling on this issue shows there is a recall out for the bumper rust issue. Recal is R23, i would mention it to the dealer.
Old 01-13-2011, 09:59 AM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
Originally Posted by marcus View Post
quick googling on this issue shows there is a recall out for the bumper rust issue. Recal is r23, i would mention it to the dealer.
what models are effected by this recall
Old 01-13-2011, 03:11 PM
Duckhunter Duckhunter is offline
Vehicle: 2013 Dodge Ram 4 X 4 CC
Trim Level: SLT Bighorn
Color: Deep Cherry Red
Duckhunter is on a distinguished road
Dealer replaced my front bumper no questions asked. It just had a little surface rust starting to show on the top edge under the painted trim lip.
Old 01-13-2011, 03:23 PM
rfdlt20's Avatar
rfdlt20 rfdlt20 is offline
Vehicle: 2011
rfdlt20 is on a distinguished road
Oh Oh , This is not a good sign ! Do they use a ton of salt in Canada ? Maybe its to to the longer duration of salt exposure ?
Old 01-13-2011, 03:33 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
My 2008's chrome bumpers are doing okay.
One thing I do to keep rust in check is I apply a very, very light coating of white lithum grease around the most vunerable areas (like rivets and bolts) on the back-side of the bumpers (not the front side). I only apply a dab on the bolt/rivet and swirl it around the base with my finger. It defintely helps keep rust away. I am sure there are better applications than white grease but it works for me and you cannot see it.
Old 01-13-2011, 04:05 PM
Rep:82
SO YOU PUT LITHIUM GREASE ONLY ON RIVETS AND BOLTS AREA and what do you mean back side not front side
Old 01-13-2011, 04:19 PM
Freightrain's Avatar
Freightrain Freightrain is offline
Vehicle: 2011 dodge ram Quad Cab 4x4
Trim Level: chrome
Color: red
Rep:60
Freightrain will become famous soon enough
I think he means on the "Inside, not on the Outside"
"The End is Near, I'm just gonna get there a little faster"
Volant CAI, 4" Nerfs, Tonneau Pro Cover, 18" Magnaflo, more to come
Old 01-13-2011, 04:23 PM
Rep:147
What I meant by "back side" is the side of the bumber facing the truck (not the side facing you when you are looking at your truck). The back side is where the bulk of salt will get into and is where most connections are made.
Lithum grease is a very good rust inhibitor. Also, when I apply it (with a small paint brush), I let it bake in the sun as it does harden to some degree when you put a thin layer on. I do this since it attracts less dirt then if I were to drive immediately after putting it on. I do use it on other underneath connecting parts such as plow brackets, tow hooks etc. It does work. the trick is not getting it over everything when you apply it.
Old 01-13-2011, 04:40 PM
Rep:82
I may do this what if i put wd 40 and spray it underneath
or what about rust proofing at the dealership ????
Old 01-13-2011, 05:03 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Ultimately, in Salt land, nothing will prevent it. But a true UNDERCOATING will extend the life of your truck by umm...well...ALOT.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-30k miles-BF Goodrich Rugged Terrain T/A, Mufflex Muffler Delete, Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist, Total Load Control, AVS Visors and Bug Shield, K&N Drop-In, XenonDepot 5000k LED Headlamps in factory projectors.
