Old 01-11-2011, 09:50 PM
PigzFly PigzFly is offline
Vehicle: 2010 Ram 1500 Sport CC
Trim Level: SPORT
Color: Black on Black
Rep:33
PigzFly is on a distinguished road
Default Aftermarket Control Arms
Anyone have a source for aftermarket lower control arms?
I have a ProComp 6" lift and while trying to figure out the turn radius issue fount that I am having contact between the spindle and the lower control arms. The spindle has been digging and cutting into the lower amrs and my best guess is to replace them, hopefully with something heavy duty. I have not been able to find anything yet. I know that there were a couple of companies that offered control arm upgrades for the Titan, but cant seem to find them for the ram. Thanks for the help!
2010 Ram 1500 SPORT Crew Cab
ProComp 6" lift - 22" XD Monsters w/ 35" Toyo MT's
Old 01-13-2011, 11:08 PM
Have you contacted Pro Comp about this issue ?
Old 01-15-2011, 12:49 AM
Crawler Hauler Crawler Hauler is offline
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Crawler Hauler is on a distinguished road
x2. Before you look at other components, talk to the manufacturer first.
And if you decide you need aftermarket control arms, you might as well have a set built by a decent off road shop. They will need to be adjustable to dial in the castor you need with the compnents from the Pro Comp kit. But I would not suggest this route.
Old 01-15-2011, 01:17 AM
purodude's Avatar
purodude purodude is offline
Vehicle: 2012 ram 1500 crew cab
Trim Level: sport
Color: bright white
Rep:16
purodude is on a distinguished road
ebay has everything you'll need.
