Old 01-12-2011, 07:17 PM
hawk5124 hawk5124 is offline
Vehicle: 2006 Dodge Ram quad cab diesel
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
hawk5124 is on a distinguished road
Default Wheels and Tires
HI Guys,
Can anyone help me? I have a 2006 2500 quad cab diesel 4x4. I want to put bigger tires on it because the stock 265/70/17's look like tricycle tires on it. I was told I could put 33's on it without lifting it. The problem is, I cant seem to get a definitive answer as to what wheel offset I need. I want to put Nitto 295/70/17's on w/ KMD xd 796 revolver rims but was told I couldnt because of the -12 offset. What offset do I need?
Old 01-13-2011, 10:58 PM
My 1/2 ton came with 33's from the factory . I put a 2" leveling kit on it and have been running 35's . I'm not up on offsets so maybe someone else can answer that one for ya .
Old 01-13-2011, 11:00 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I would just ask the wheel shop, if they can't answer that for you....you need to find another shop! They can measure it for the proper offset
Old 01-13-2011, 11:14 PM
thanks guys I appreciate it
Old 01-13-2011, 11:21 PM
916Timmy's Avatar
Rep:1443
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Good article on wheel offest, should give you a better idea of what you need! The more positive offset you have, the closer the wheel will be to rubbing inside the wheel wells.
