Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Place your Ad Here!
Old 01-12-2011, 07:46 PM
agood6000198 agood6000198 is offline
Vehicle: 2003 Dodge Ram 1500 5.7 HEMI
Color: Maroon
agood6000198 is on a distinguished road
Default changing 1500 to 2500? hemi to cummins
I have a 2003 Hemi and I also have a Cummins engine I am wandering what all in the body and suspension and frame i would need to change?
http://www.ramforumz.com/showthread.php?t=54845
Infinity sound help needed
Old 01-12-2011, 08:05 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
Not sure as I am not nearly techncial enough. Will a Cummins fit into a 1500? A Cummins is far heavy than a Hemi. Definetly will need to look at your FGAWR.
Good luck and would love to know how it comes out if you actually make the change.
Old 01-12-2011, 08:17 PM
Color: Maroon
My friend totaled their truck but the engine is fine so I can get it cheap I am hoping it will work
Old 01-12-2011, 09:26 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
If the engine will fit you will need all the rest of the drive-train plus all the electronics and wiring, fuel system and most likely have to beef up the suspension if not replace it with the 2500 setup.
Brian:
Old 01-12-2011, 09:36 PM
Wow , your looking at doing alot of work . I'm not sure if the engine will even bolt up . Plus your looking at doing the front suspension to handle the extra weight and thats just the start of it .
Old 01-12-2011, 10:27 PM
Rep:3337
This swap is a LOT of work, but something I've been wanting to do for a long time. A couple of questions: which cummins is it, there are several 5,9Ls and the 6.7L as well. They will all fit into a 1500 engine bay, but you may need to notch the center channel to get proper fitment of the tranny.
Things you will need to swap:
engine and tranny (duh)
ECM for the cummins
Fuel pump and tank
Upgrade to 2500 springs to stop the front sagging
New battery as the cummins is a harder beast to crank
And if you decide not to do the swap... I know a good home for the cummins
Old 01-12-2011, 11:15 PM
Color: Maroon
its out of a 2001 2500 so its a 24 valve and i am moreso wandering if it is cost effective at all? like how much would it cost to get a 2500 suspension? and would i need to box in the frame or just specific places? i wont be doing much if any hauling with it so is there anything else i would need to do?
Old 01-13-2011, 12:01 AM
Color: RootBeer
Rep:1287
Do you have access to the donor vehicle? If so, go take a good look and compare it to your truck.
Brian:
Old 01-13-2011, 12:04 AM
I was gonna recommend that if it totaled out due to extensive body work , rebody it with your body .
Old 01-13-2011, 12:44 AM
Rep:3337
Not a bad suggestion tom. And good, cost effective is a relative term. Having all the parts, and if you know what you're doing, you could probably do it fairly cheap, but if you're gonna have someone else do it for you, then you have to ask yourself if it's worth it to YOU. If I personally had access to a 24V 5.9L, you'd better believe I'd be looking for a truck to put it in, maybe even a dakota
