Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
tonneaucovered.com
Old 01-12-2011, 10:04 PM
dminted dminted is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: sport
Color: deep water blue
dminted is on a distinguished road
Question Door lock wiring
Does anyone know what the color code is for the power door locks on 2009 ram? I recently purchased the powergate lock from pace edwards and the directions indicated the wiring for the door locks were tan/green and tan/white. the only problem is there are no tan/green and tan/white wires. Any help would be greatly appreciated.
Old 01-12-2011, 10:32 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Go to http://www.ramtrucks.com click on "body builder's guide" and pull up the wiring diagram for your Ram.
How about stopping by our Newbie area and introducing yourself.
Brian:
Old 01-12-2011, 11:45 PM
Trim Level: sport
ive tried it but it only comes up as a .pdf file
Old 01-12-2011, 11:55 PM
Color: RootBeer
Rep:1287
Click on the link for 09 in the first post. Color codes are in a different part than the diagram itself and yes, its a pdf.
http://www.ramforumz.com/showthread.php?t=69949
Brian:
Old 01-14-2011, 06:44 AM
79ta 79ta is offline
79ta is on a distinguished road
I will look at the diagram as well because I'm having an problem with fuse 27 in my 2009 2500 4x4 cummins. Owners manual says it feeds power seat(s) and it continues to drain my batteries when plugged in. Did the standard voltage check with the key off while unplugging fuses one at a time and theres a significant current draw from this fuse. Without fuse 27 installed, voltage is a consistent 12.48. Has anyone had this problem? I'm guessing there is a relay or something that may have failed. I have read about some seatbelt retractor issues from earlier years. I'll take a closer look at it this weekend. Should add that I do not have heated seats.
Old 01-14-2011, 10:00 PM
Well my issue has been fixed. The problem was one of the three switches (the rear most) on the drivers side was pinned under the cover holding it in the down position. Freed the switch, re-installed the fuse and checked for voltage drop. Meter read 12.48 and steady. I'll check it later this weekend to be sure.
Old 01-18-2011, 09:27 AM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
I think this is what you want.
http://nnoxaa.blu.livefilestore.com/...ownload&psid=1
Old 01-18-2011, 09:32 AM
Rep:82
There is a fantastic write up for the OEM tailgate power lock actuator here:
http://www.ramforumz.com/showthread....tailgate+power
Old 01-27-2011, 11:01 AM
Rep:82
Strange that link doesn't work....
Does this?: http://goo.gl/73qh9
[Edit] This one quit working too.....I'll see if I can convert to jpg and host it somewhere.
Old 01-28-2011, 09:10 AM
Rep:82
Ok, this should stay working - I hope! LOL
