Old 01-12-2011, 10:44 PM
69speeder69's Avatar
69speeder69 69speeder69 is offline
Vehicle: 2001 Dodge Ram
Trim Level: Laramie SLT
Rep:18
69speeder69 is on a distinguished road
Default P0305
I got a check engine light today. Went to checker to read it and it says its a P0305 misfire in cylinder 5. What can i do to fix this problem? What are reasons for it?
Old 01-12-2011, 10:56 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
Wow! Could be a number of things.
A few off the top of my head:
1. Bad, fouled, or improperly gapped spark plug.
2. Improperly installed/attached or damaged coil.
3. Clogged or malfunction of fuel injector.
4. Leak in head gasket near #5.
5. Low compression.
The list goes on.
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 01-12-2011, 11:57 PM
Rep:18
Its weird cause I did the spark plugs, wires, cap and rotor about 6 months ago. And it just started throwing the code tonight. Where should I start to try to figure this out?
Old 01-13-2011, 12:22 AM
Could be a bad plug , wire , cap , low compression or maybe even a bad intake plenum gasket . Are you using oil at all ? With the motor off open up the throttle and look down into the intake manifold to the floor and see if there's any accumulation of oil . If there is , more than likely you bad to reseal the plate on the bottom of the intake manifold .
Old 01-13-2011, 01:00 AM
Rep:18
K i will check my plugs wires cap coil and inside of my throttle body tomorrow. I dont have a compression tester so I will wait on that one for now.
