Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-13-2011, 12:41 AM
zgrant zgrant is offline
Vehicle: 2004 dodge ram 1500
zgrant is on a distinguished road
Default control switch not working correctly
i was wondering if anyone could help me out. my heat gets hot but the controls dont work right. i have for different speeds on the blower control, the first two work fine but the third dont blow at all and the forth blows cold air. im not sure what it might be and i was hoping somebody could tell me something before i start taking things apart
thanks
zach
Old 01-13-2011, 07:47 PM
Rep:1885
Sounds suspiciously like a 2 part problem. The blower not working on the 3rd speed is most likely a bad blower motor resistor - a simple fix. If the air is going cold on high speed you may have a blend door problem.
Old 01-13-2011, 11:27 PM
thanks for the help. i was thinking about the resister and was going to change it. how might i go about checking the door problem?
Old 01-14-2011, 01:39 AM
Unfortunately the blend door problem means a deep dig into the dash.
Try cycling your HVAC function switch (heat floor to bi-level to defrost) back and forth. You should hear the door cycling. If it's stuck you won't hear it move.
Old 01-14-2011, 11:26 AM
Thanks alot, ill try that
Old 01-14-2011, 11:32 AM
Rep:2657
zgrant, to help you to figure it out, there are a set of videos, that show how to go about trouble shooting & also how the repair is done
2002 - '08 videos
http://www.heatertreater.net/Dodge%20Product%20Page.htm
