Old 01-13-2011, 04:49 PM
Hawkinsgold Hawkinsgold is offline
Vehicle: 2011 Ram 1500 crew
Trim Level: Sport 4x4
Hawkinsgold is on a distinguished road
Default 115v/150watt power outlet uses
My 2011 Ram Sport has a 115v/150watt power outlet in the dash. I was planning on using 2prong/3prong adaptor to use my laptop. I would plug the adaptor into the power outlet and then plug my 3prong power cord into the adaptor to run my laptop. Laptop is rated at dc 19v-6.32 amp. I have read various opinions on whether it is safe to use the outlet for the laptop leaving me somewhat confused as electricity is not my specialty by any means. Any assistance would be appreciated.
Les
Old 01-13-2011, 04:59 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
I think you should be fine although I would look at your laptop's manual to read if there is anything you should be aware of.
Your laptop runs on DC power, even when pluged into a 110/120 v AC outlet. The laptop cord (the box on the cord) converts AC into DC. Thus, regardless of the power source for the 110/120v, your laptop should regulate it to the appropriate DC power. To be safe, I would use a small surge protector to avoid issues should your truck's power flucatuate as you are using your laptop. Same holds true if plugged into your house outlet.
Old 01-13-2011, 05:10 PM
tcarlton0516 tcarlton0516 is offline
Vehicle: 2014 Ram 2500 Crew Cab 4x4
Color: Blue Streak
tcarlton0516 is on a distinguished road
You'll need to keep the Wattage below the 150watt max. To calculate watts Watts=Voltage x Amps. Check the AC adapter on the laptop you should find the information required to calculate the watts there. Mine shows 120V and 1.9 amps so the watts would be 228 watts, very safe to use in the RAM. I don't know if I would use the three prong to adapter though?
Old 01-13-2011, 05:25 PM
Neat feature . Got a pic of it ?
Old 01-13-2011, 05:50 PM
I push the skinny pedal
Rep:3277
One small issue with going from a 2 prong to a 3 prong is your laptop will no longer be grounded. If i'm using a lap top in the truck, I went out and got a 500W power inverter that plugs into the 12V outlet. I know it's not the same as just plugging it in, but this way you'll keep your ground and have 2 fuses between your laptop and a power surge,
Kurtis
Old 01-13-2011, 06:33 PM
Rep:2657
I have used my laptop with my Ram for 18 months, but, it only has a 2 prong electrical plug
Old 01-13-2011, 09:39 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Originally Posted by tcarlton0516 View Post
You'll need to keep the Wattage below the 150watt max. ,,,,,,, Mine shows 120V and 1.9 amps so the watts would be 228 watts, very safe to use,,,
Uh, something just ain't adding up here,,,, Is 228 below 150???
Old 01-13-2011, 09:45 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I think most of the newer laptops have 2 prong plugs....my older one has 3
My 10.1" netbook is outputting 19 volts at 2.1 amps or 40 watts...That is well below 150 and I have a two prong plug!
Old 01-13-2011, 09:51 PM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
You're looking at the wrong side. Some power is consumed in the rectifying and regulating your 19VDC so you need the power draw on the AC side of the charger. I'm sure you'll still be ok, but to do it right you have to use the AC numbers.
Old 01-13-2011, 10:16 PM
916Timmy's Avatar
Rep:1443
The input says 100-240v, 50-60Hz, 1.0 amp
so I'm h=guessing 110 watts?
