Old 01-13-2011, 08:04 PM
str8hemi's Avatar
str8hemi str8hemi is offline
Vehicle: 2005 Dodge Ram
Rep:49
str8hemi is on a distinguished road
Default Higher amp. alternator
I have an 05 dodge 1500 5.7. The issue I've been having is that everytime i'm at a light or complete stop and hit the accelerator the lights on the gauges and radio dim a little sort of like a flicker and when I let off they stop. But it will only do it in the initial take off. I've also noticed that the drvier side headlight bulb(HID) will do it also. Battery is new and alternator is charging at 14.33v. Could it be possible that I need a higher amp. alternator?
Old 01-13-2011, 08:13 PM
I push the skinny pedal
Rep:3277
Unless you have a major sound system, the stock alternator should flow about 110 Amps (it's rated at 130A). I could see a potential issue if you had a loose battery/ground connection, but the alternator should be fine. I'd head to you auto shop and see if they can do an alternator test to see what it's putting out. If it's dropping or very low output, then your alt is on it's last legs and should be replaced.
Kurtis
Old 01-13-2011, 08:16 PM
Valve's Avatar
Valve Valve is offline
Vehicle: 2005 Dodge Ram 1500 Quad 4x4
Rep:141
Valve will become famous soon enoughValve will become famous soon enough
Could be a Bad ground.Any aftermarket upgrades,Stereo,amp,Etc
Line-X : Extang : Python 990 SSLCD : Tailgate Lock with Doors :
Fog Light Toggle Bypass : AeroTurbine at3030 : Tint match rear QC : SilentArmors on stock 20s(nitto and wheels in Future)
2005 Dodge Ram Service Manual
Old 01-13-2011, 08:45 PM
Rep:2616
any good auto electric shop can BOOST the output of an alternator
if you are running a lot of accessories, audio components, extra lights, etc. you could buy a 200 amp alternator for about 5 or $600
they also make smaller pulleys for alternators, making it spin faster
if your alternator is found to be working properly, you could look into something like this http://powerbastards.com/proddetail....=Fitzall%2D220
Old 01-13-2011, 08:54 PM
RamTech RamTech is online now
Rep:1845
I'm with Kurtis on this one. Have the alternator output checked and make sure all connections are clean and tight.
Old 01-13-2011, 09:15 PM
SnowChief SnowChief is offline
Vehicle: Ram 2500 SLT Quad Cab
Rep:147
SnowChief will become famous soon enoughSnowChief will become famous soon enough
The other thing to think about is the bushings in your alternator may be on their way out. When this happens, your alternator may actually convert less AC to DC, resulting in a lesser charge to your battery. I agree with the other threads that you need to have your alt checked to see its output at idle and at higher rpms. One other thing is ensure your alternator belt is tight. If it is loose, the same effect can occur - less output at higher rpms due to belt slippage.
God luck.
Old 01-13-2011, 10:42 PM
str8hemi's Avatar
Rep:49
ok thanks i'll have it checked out.
