having pinion gear problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Diesel Forums!
Dodge Caliber
Newbie Checkin! New to the forums? Introduce yourself here!
Place your Ad Here!
Old 01-13-2011, 08:52 PM
rhinox420 rhinox420 is offline
Vehicle: 96 dodge ram 1500 2wd
Trim Level: n/a
rhinox420 is on a distinguished road
Default having pinion gear problems
hi i have a 96 dodge ram 1500 the other week i did a service on the differential. i drained out all of the lube or oil and installed a new cover gasket and filled back up with gear oil drove it and drove fine. had a little rear end noise parked it and checked for leaks. found a big leak coming from pinion seal and also found that the bearing behind the seal was bad. so i ordered all new bearing for diff. all 4 of them and pressed all of them on except for the outer pinion bearing behind the seal. ok the problem iam having is when i start to tighten up the pinion nut on the yoke it gets very hard to turn. if i losen the nut and truns free hope maybe you can tell me if this is normal. also the diff has no oil should it be that hard to turn with no oil in it thanks
Old 01-13-2011, 09:20 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
Hello and welcome!
Good to have you with us, I hope you enjoy the board! I am sorry, I can't help you with your problem but others here can.
Old 01-13-2011, 10:08 PM
Glad you joined us and welcome to the Z for Rams from Baltimore . Did you replace the crush sleeve also ? As long as the threads on the pinion look fine , I'd replace the nut . Do you have any pictures of your truck ? Have you done any mods or have plans for any ? Any of your friends have Rams ? Tell them about us . We would love to have them . You will find this site is full of a lot of talented people . So if theres any question that you need answered , just shoot away . Talk to ya soon . Tom
Old 01-13-2011, 10:13 PM
Rep:1625
Welcome to the forum! Great to have you here!
Old 01-13-2011, 10:18 PM
Trim Level: n/a
Default pinion gear hard to turn by hand
hi again i also iam wondering if the collapsible spacer on the pinion shaft needs to be replaced could that be the reason it feels like it is locking up or is very hard to turn by hand any info would be helpful thanks
Old 01-13-2011, 10:26 PM
Trim Level: n/a
no i just replaced all the bearings. my haynes book shows a collapsible spacer between both inter and outer bearings. do you know if or when you replace the bearings are you also replace collapsible spacer thanks
Old 01-13-2011, 11:52 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
welcome to the forum!!!!
Old 01-14-2011, 06:53 AM
Rep:4253
Hello and welcome to the forum, glad to have you join us! Sorry to hear you're having problems. Had my pinion seal replaced twice under warranty since owning my truck, so I didn't do it myself, but good luck and be sure to keep us posted! Any pics of your truck? We'd love to see it! Lots of great people and info here, so any help you need, just ask and I hope you enjoy the site!
Old 01-14-2011, 10:12 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
hello and welcome, any pics of your truck?
Old 01-14-2011, 10:18 AM
Chili1K's Avatar
Chili1K Chili1K is offline
Trim Level: TRX4
Color: Email: Chili1k@att.net
Rep:1092
Welcome to the site, sorry to hear about your troubles.. Im sure someone hear can help!
