Old 08-18-2013, 09:53 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
What electronics are fighting the mods? When you increase airflow in/out of the engine the pcm will increase fuel injector pulse width(duration that the injector is injecting fuel) to keep the same desired A/F ratio. The electronics work with mods, as long as they are within the pcm's range. Intakes/exhausts are within that range. All a tuner does is adjust ignition timing and sometime desired A/F ratio.
The stock exhaust on 4th gen rams, including the muffler, is all 409SS, so it should last the life of the truck, unless in extremely harsh conditions.
I just looked at the first pic again and that one rusted pipe is definitely not 409SS. My muffler didn't look like that when I cut it open, with about 75000 miles on it it had no rust, it was all SS.
Sean
Old 08-18-2013, 07:09 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
I think it's good the Chrysler put duals on our trucks but the quality of the welds and the piping is shitty. Check them out on your duals by the tail pipes and check out the rust on them. They look like popcorn welds, ugliest welding jobs I've ever seen on a new vehicle. To the OP, good thread.
Old 08-18-2013, 07:18 PM
RadioFlyer's Avatar
Rep:146
Originally Posted by 916Timmy View Post
That looks as good as a New Orleans sidewalk after Mardi Gras! Glad I have a package from Magnaflow on the way!
....it's not as bad as Louisiana highways. You could probably hide them in some of the in the potholes!
Old 08-20-2013, 12:39 PM
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
snrusnak...are they still using ss on the interior of the muffler or did that change after your model year.
Old 08-20-2013, 01:47 PM
snrusnak's Avatar
Rep:1385
I can't say for sure as I don't know the sourcing of the pipe, but in the pic at the beginning of this thread everything appears to be SS except for that one baffle that is rusted badly. Also is possible that all three baffles are not SS and only 1 is rusting.
Sean
Old 08-20-2013, 10:10 PM
Trim Level: sport
Color: green
Rep:677
tks snrusnak.........
magnaflow y-pipe, ram express hemi exhaust
