Old 01-14-2011, 04:53 PM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
Default About to hit 3000 miles on 2010 Ram Quad Hemi - noob questions
I searched some .. I read some.
- I see I have a lock id card for my wheel locks. Is there a key already in the truck somewhere? where?
- I've never used synthetic, not sure I want to start. Yeah it's got a hemi, but so what? .. what oil should I use. I have a $50 credit from the dealer will that be enough? Anybody else reluctant to take their truck to the dealer? for me, this dealer is 50 miles away, but I have a credit there.
- I'm currently only getting 11.5 mpg. yeah... I will talk to them about this. Worth going with K&N air filter?
Anything else I should consider?
Thanks.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 01-14-2011, 06:21 PM
moparornocar72's Avatar
Rep:630
!.The wheel lock should be in your glove box.
2.It's purely up to you on the synthetic oil but once you switch your not supposed to switch back.
3. Keep your foot off the pedal so much and you will get better. A k&n drop in filter will help.
14.268 @ 95 MPH Full Trim
Old 01-14-2011, 06:49 PM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:39
BlackBullet is on a distinguished road
i made the switch to synthetic
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 01-14-2011, 07:21 PM
Rep:2616
the choice of oil is up to you, continue using dinosaur oil or synthetic
My wheel lock was attached to the jack, under the passenger front seat
by the way, be extra careful when using that jack, they don't make them like they should
K&N air filter is recommended by the Ram dealership & i have had good results with it, i put mine in at 30,000 miles, the old one was filthy
as for the mileage, forget that digital read out, fill the tank,write down the mileage, drive the Ram, fill up when you want, write down the mileage, then use an adding machine or paper & writing utensil & figure it out. The damn digital readout will drive you nuts, same with watching the miles until empty thing, you will fill up one time, it may read 325 miles to empty, the next fill up it may read 500 miles until empty, i have the 32 gallon tank & just the other day i filled up, it read 330 miles until empty, 200 miles later it still read 321, it was all highway driving
By the way, my MPG got better the more i drove it, i now have 37,000 miles on it & depending how i drive it & where, i have seen 21 MPG, but, mostly 16.2 - 18.6 MPG
If you do decide NOT to have the dealership do your services, keep very good records, Date, Mileage, Location, Cost, type of oil & filter. please don't buy a cheap filter, read the box for applications, if it costs $5.00, get a better good quality filter such as NAPA, WIX, MOPAR, etc
Old 01-14-2011, 09:19 PM
What he ^^^^ said!!!
Old 01-14-2011, 10:03 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
with everyting GT said. How about clicking on UserCp at the of the forum and fill in the info about your Ram. It helps us to answer questions.
Brian:
Old 01-14-2011, 10:11 PM
^^ I agree with all three above me ^^
Old 01-14-2011, 10:18 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^^^ That is some good advice, ^^^^^
If I can just add that synthetic is less likely to break down under stress and well worth the few extra bucks. I do my own oil changes, just keep good records which GT has already stated.
Old 01-14-2011, 10:26 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
You can get a Mopar oil filter at WalMart for $5.00, so that's not too bad.
www.beatcraigslist.com - for posting dangers & secrets
Old 01-14-2011, 10:29 PM
vettaboy's Avatar
vettaboy vettaboy is offline
Vehicle: 2012 Ram 2500
Rep:35
vettaboy is on a distinguished road
Use the credit on the oil change now, at the 6000 mi mark change over to synthetic oil and a high quality filter. Then you should be right on the service schedule with an oil change every 6000 mi. A K&N Filter goes into every one of my vehicles as soon as I drive them off the lot.
