Front drive shaft,Transfer case, Bearing ????? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-14-2011, 05:47 PM
d12002's Avatar
d12002 d12002 is offline
Vehicle: 2002 dodge ram 1500
Color: silver
d12002 is on a distinguished road
Default Front drive shaft,Transfer case, Bearing ?????
I have massive wobble in my front drive shaft. I made a quick 39 second youtube video so you can see.
Does anyone know if this is a bearing needing to be replaced or is my whole transfer case shot. Any help would be great.
4wheel drive only shifts into 4-low Gets stuck trying shift into 2-high or 4-high, then really have to work the shifter to get back and rolling on 2 wheel drive.
Thank You
Old 01-14-2011, 11:21 PM
foulwhitey foulwhitey is offline
Vehicle: 05 ram 1500
Rep:35
foulwhitey is on a distinguished road
if the problem ended with the drive shaft, i would think a replacement would be your fix. since you mentioned problems with getting in and out of 4wd, my guess is transfer case and some cash involved in repair.
Old 01-14-2011, 11:28 PM
Have you checked to see if theres alot of movement right at the transfer case ? The video really doesn't help me with that view . Is the seal at the transfer case leaking from alot of movement ?
bearing, drive shaft, transfer case
