Ignition Switch and Fan Blower Problem - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 01-14-2011, 07:02 PM
steelman512 steelman512 is offline
Vehicle: 2002 Dodge Ram 1500 SLT 5.9L
Rep:27
steelman512 is on a distinguished road
Default Ignition Switch and Fan Blower Problem
So I have this issue where the fan blower stays on when I turn the truck off. If I wiggle the key around or turn it off slowly I can get it to kill the vent blower, and it seems this issue lies within the igniton. So......I bought an ignition switch at Advanced Auto for around $35, it's just a black piece of plastic with connections on both sides for wire harnesses. I have the top of the steering column off, but can't get the tilt wheel lever off to remove the bottom.......??? Also anybody have info on swapping the switch out? I already know how to remove the airbag, etc.
Old 01-14-2011, 07:03 PM
Rep:27
By the way its an 02 Dodge Ram 1500 Quadcab 5.9L
Old 01-19-2011, 02:08 PM
rotorhead0923 rotorhead0923 is offline
Vehicle: 2005 dodge ram
Color: blue
rotorhead0923 is on a distinguished road
Default re: ignition switch and fan blower problem
I have the same issue, only sometimes the fan won't come on again for a while. Did the new switch fix your problem?
Old 01-19-2011, 02:50 PM
Resident Technician
Rep:1915
You just have to pull hard on the tilt lever to get it to come off.
Old 01-19-2011, 05:09 PM
Rep:27
Yeah the switch fixed the issue, and it was about $30 at Advanced. RamTech you were right just pull the tilt steering lever to you until it pops off. Use a #20 stardriver to remove 3 screws on the bottom cover. Remove the top and bottom of steering column. Remove neg battery terminal, insert your key and turn to on. Insert a screwdriver up underneath the ignition and push in a spring loaded pin until you can wiggle the key+ignition out and place to the side. The electronic switch is on the left side of the column and has a couple quick disconnects and a couple screws. Just swap and put it back together. Hope this helps.
Old 01-19-2011, 06:06 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Great detailed report. Don't suppose you got pics, huh?
Brian:
Old 02-09-2011, 01:35 AM
loveday.ag loveday.ag is offline
Vehicle: 2003 Dodge Ram 2500
Color: Gray
loveday.ag is on a distinguished road
Ok I am going to buy a new switch in the morning. I have to drive 5 hours to a funeral and the highs are only suppose to be in the low 20's. Heat would be great!
Old 08-09-2011, 09:34 AM
farmboy69 farmboy69 is offline
Vehicle: 2003
farmboy69 is on a distinguished road
Thumbs up Ignition switch and connector charred
I have the same problem with my 2003 Ram. The ignition switch and the connector both had charring on the 1 and 8 terminals affecting my blower motor and security system. The blower motor is powered by the dark green wire and the security system by the pink/black. I see there are issues with the switch and didn't realize they were an issue and never had problems with mine til last week and Ive got 180,000 miles on it. Glad to hear a new switch cured the problem I'm getting one today. Just joined the forum today and glad to be a member.
Old 02-29-2012, 07:54 PM
geneshereen geneshereen is offline
Vehicle: 2004 dodge ram
Trim Level: slt 4x4
Color: charcoal
geneshereen is on a distinguished road
my 04 ram interior fan goes off whenever I tilt the steering wheel down. I removed the steering wheen shroud and I see a black plastic box on the left side with the word VALEO on it. when I move this box, the fan comes on. So I took an electrical strap and strapped it up against the column so now the fan works all the time. I fear this is just a temporary fix so I am wondering it that is the part that need s to be replaced and if so, what is it called.?
thanks Gene
Old 06-14-2012, 10:42 PM
majake01 majake01 is offline
Vehicle: 2003 dodge ram 1500 hemi
majake01 is on a distinguished road
Default Any resolution
thanks Gene
geneshereen, I have exactly the same problem. Did you ever get a satisfactory resolution to your problem?
