Old 01-14-2011, 09:20 PM
Gergas Gergas is offline
Vehicle: 2007 Ram QC 4x4 BigHorn
Rep:100
Gergas will become famous soon enoughGergas will become famous soon enough
Default Leveling kit installation problems. Help!
I'm installing a 2.5" front leveling kit on my '07...at least I tried to. For some reason I cannot get the ball joint to separate from the upper control arm AND also I cannot get the steering linkage to separate either. The instructions say to hit the side of the knuckle with a hammer and everything should come apart. Not for me apparently. After a few hours of...hammer time...penetrating lube...hammer time...penetrating lube...beer time...hammer time...beer time...beer time...I gave up. Is there a trick I'm missing? Can I just get a spring comperssor and remove it that way? I hate it when a 2 hour job turns into a 2 day job. Please help!
Old 01-14-2011, 09:53 PM
CapperRAM's Avatar
CapperRAM CapperRAM is offline
Vehicle: 2013 RAM Power Wagon
Trim Level: Power Wagon
Rep:205
CapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura aboutCapperRAM has a spectacular aura about
You need a ball joint fork..
Probably run you about $20 at the local parts store!!
This could also help you with the steering linkage, you may need a smaller one(narrower fork)..
Good luck and hope this helps!
Old 01-14-2011, 09:58 PM
foulwhitey foulwhitey is offline
Vehicle: 05 ram 1500
Rep:35
foulwhitey is on a distinguished road
pickle fork and hammer from your local auto parts store. after a lot less work than you've done already, you'll have them apart. those types of joint form a 'mechanical weld'. when you use the pickle fork, it is quite possible you'll tear the rubber boots on the control arm and tie rod ends - be prepared for it. finally, when you put it all back together, make sure your nuts/bolts are torqued right
Old 01-14-2011, 10:49 PM
Rep:100
I tried one from Harbor Freight...no go. Do I need a "real" one?
Old 01-14-2011, 10:56 PM
CapperRAM's Avatar
Rep:205
Undo the nut????
Old 01-15-2011, 03:44 PM
wedgeheaded's Avatar
wedgeheaded wedgeheaded is offline
Vehicle: 06 1500 QC 4x4
Rep:111
wedgeheaded will become famous soon enoughwedgeheaded will become famous soon enough
Try backing up the other side of the knuckle with another hammer. Thats how I do it anyway.
