Old 01-14-2011, 11:56 PM
94ram1500's Avatar
94ram1500 94ram1500 is offline
Vehicle: 1994 Dodge Ram
Trim Level: SLT Laramie
Color: Green
Rep:139
94ram1500 will become famous soon enough94ram1500 will become famous soon enough
Default Trans rebuild
Monday evening on my way home from work, I noticed the trans shuddered going into 2nd gear. Wondering where that came from, it banged overdrive pretty hard a few minutes later. Sitting in traffic I figured I'd service the trans this weekend, when all of a sudden I heard the front pump start to howl and I lost all of my gears. I managed to limp it to a parking lot where I could let it cool down and I walked home. I came back a couple of hours later and fired it up, put it in drive and it went right into gear. I got it home and in it's parking spot in time to lose everything again. Needless to say, it's getting serviced now.
If it's ok with everyone here, I'll try to explain with pictures what is going on thoughout the process.
Remove trans pan to drain fluid.
1st: disconnect the battery. Spray all nuts/bolts that may be rusty with
WD-40, PB Blaster or your favorite rust buster.
Remove the starter, two block to trans braces, converter cover and torque converter bolts (4) remove the center brace that the trans mounts to. Carefully remove the spring clips that retain the cooler lines into the trans and work the lines out of the fittings. Rmove the exhaust pipes from the manifolds and remove the O2 sensor so it doesn't get damaged. disconnect the electrical plugs, carefully pry the kickdown cable from it's ball. Rmove the nut/bolt that holds the kickdown cable bracket. Remove the bolt that holds the shifter linkage.
Now remove the 6 bolts in the bell housing--4 rear 2 in front. Note: you will have to remove the oil filter as one bolt is behind it. Once all the bolts are removed, seperate the trans from the engine block using your choice of prying utensils. (please have a jack of some sort under the trans at this point.) As the trans is moving away from the block, be sure that the converter is staying with the trans. Slowly lower and move the trans back while keeping wiring and cooler lines from getting caught.
Once you have it lowered it should look something like this:
Once I got it over to the bench, I removed the speed sensor and tailshaft housing and the pan.
Next I removed the shifter/kickdown linkage. They have a "flat" side to them so they only go back on one way. These are secured using pinch bolts.
Once these are off, there are about 12 bolts that hold the valve body to the trans case. Take those out and carefully remove the valvebody.
Now you see what is left, the front pump, the drums containing the clutch discs and clutch plates, the two bands and servos that control them
Getting back to my trans pan, you will notice the brownish tint to the fluid. Not really good. Not bad, I've seen worse but it strill has that hot clutch material smell to it. There is a small amount of metal in the pan and on the magnet. I'm hoping thats from the the clutch discs and plates.
Thats as far as I got today, I'll update this with more info and pics sometime during the week.
Please note: No one from Ram ForumZ.com or the originator of this thread can or will be held responsible for any injury or damage that could occur from trying this yourself. If you are not sure, please consult professional help.
Can someone please tell me, why common sense is so uncommon these days??
Old 01-15-2011, 12:18 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Great project report with pics too.
Brian:
Old 01-16-2011, 05:51 PM
aftershokk86's Avatar
aftershokk86 aftershokk86 is offline
Vehicle: 01 ram 1500 ext cab
aftershokk86 is on a distinguished road
Thanks for the pictures, im real interested in your trans rebuild.
What kind of kit are you using to rebuild, or replacing certain parts?
Are you familiar with Dodge Trans much? I want to rebuild and upgrade at the same time. i was hoping to put a diesel auto behind my 5.2 because i want to tow with my truck, but found out it wont bolt up and its a 5k transmission from transmissioncenter.com to get a built diesel trans stuffed inside a custom case to go behind my 5.2
any brands of torque converters better than the next?
01Ram: infinity reference 6x9's/5.25's|kicker 12cvt|400w4channelamp|2500wmonoamp|
Old 01-16-2011, 10:03 PM
94ram1500's Avatar
Color: Green
Rep:139
I'm pretty much doing a stock rebuild, nothing more. I got a rebuild kit from Advance that looks like it will do the trick.
I really don't have an answer for upgrading your current box for towing. You could contact TCI and see what they might offer but I think they are like Summit and Jegs, more for high performance/racing applications. The same answer as far as a converter. Sorry I can't help more
Old 04-07-2011, 09:49 PM
cgoldsberry's Avatar
cgoldsberry cgoldsberry is offline
Vehicle: 1998 Dodge Ram 1500 4X4
Trim Level: Reg Cab Sport
cgoldsberry is on a distinguished road
this is awesome man, my tranny went out today and im going to attempt a rebuild cant wait to see the rest!!!!!
