Old 01-15-2011, 11:23 AM
redeye4u redeye4u is offline
Vehicle: 2003 ram 5.7 4dr 4x4
Color: blue pearl gray stripe
redeye4u is on a distinguished road
Default radiator and coolant
Well thursday nite my truck decided it needed a new radiator. leaking where the plastic and aluminum come together. Anyways to get it home i stopped at the loca wal mart and picked up some universal green mixture antifreeze. Was not sure what was in the truck. Orange or green. It was 1145 pm. I am replaceing the radiator today. Have been reading that mixing orange and green not good. When i change out the rad. That should take out most if not all the universal coolant i bought right. Don,t want to mess up the new rad. any and all help will be appriciated. thanks
Old 01-15-2011, 11:31 AM
Yes, do a total flush and use what the mfgr recommends on coolant for your year & engine truck.
For your HEMI, use of Propylene Glycol coolants is not recommended.
Use a 50/50 mix of Ethylene Glycol & water solution. Mopar anti-freeze/coolant formula MS-9769 was used in your truck when new and was combined with organic corrosion resistors.
So a good Ethylene Glycol anti-freeze with corrosion protection, mixed 50/50 with water, will do the trick.
Your cooling system capacity is 16.2 quarts.
Old 01-15-2011, 12:03 PM
SRTAndy's Avatar
SRTAndy SRTAndy is offline
Vehicle: 08 Charger
Trim Level: SRT
Rep:404
SRTAndy is just really niceSRTAndy is just really niceSRTAndy is just really niceSRTAndy is just really niceSRTAndy is just really nice
Great answer, Mike! Keep us posted, redeye!
BTW, I moved your thread for you!
When in doubt, read the Forum Rules
You can help support your favorite Dodge Ram site by becoming a Site_Supporter
"How To's" that will help you learn how to use the forum features can be found here!
Old 01-15-2011, 05:35 PM
Valve's Avatar
Valve Valve is offline
Vehicle: 2005 Dodge Ram 1500 Quad 4x4
Rep:141
Valve will become famous soon enoughValve will become famous soon enough
Make sure you don't use Tap water,Unless its an emergency.Mix with 50% distilled water
Or like Maddog said buy Manufacture recommendation 50/50 pre mixed.
Line-X : Extang : Python 990 SSLCD : Tailgate Lock with Doors :
Fog Light Toggle Bypass : AeroTurbine at3030 : Tint match rear QC : SilentArmors on stock 20s(nitto and wheels in Future)
2005 Dodge Ram Service Manual
Old 01-15-2011, 11:29 PM
Thanks guys. Got the rad. in and working fine. Used prestone with distilled water. 50/50 orange the good stuff. Was not that bad of a job.
Old 01-25-2011, 10:18 AM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
Dexicool? The only antifreeze that is HOAT, which is spec'd for our trucks besides the Mopar stuff is Zerex G-05, at least thats all I have found, and it is yellowish/ clear. Re-check your bottles, if it is Dexicool, please, please, please re flush it and put the correct stuff in it.
Sure it'll suck, but it'll make you a man
