Valve Cover Leaking - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 01-15-2011, 05:38 PM
nauticstar 2110 nauticstar 2110 is offline
Vehicle: 2006 Dodge Ram 2500
Color: Gray
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
nauticstar 2110 is on a distinguished road
Default Valve Cover Leaking
Yesterday while working on another problem I noticed that I was starting to leak a some oil around the valve cover gasket on my 06 2500. I have never done any work on a diesel before but have changed valve cover gaskets on gas engines with no problems. This may sound stupid but is it as simple as removing the valve cover, replacing the gasket, and putting the valve cover back on? Its not leaking a lot but would like to fix it before it becomes a bigger problem. Most of the leak is toward the back side of the valve cover. Any help would be greatly appreciated.
Old 01-16-2011, 03:14 PM
I haven't worked on one myself , but yes it should be that simple .
Old 01-19-2011, 10:20 PM
Color: Gray
Has anybody done this to their 5.9 cummins before?
Old 02-01-2011, 12:23 AM
Poriggity Poriggity is offline
Vehicle: 2004.5 Dodge Ram
Color: Molten Red/ Silver
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
Rep:93
Poriggity will become famous soon enough
Never done it, but all research tells me it should be just as easy, if not easier than a gas motor.
Scott
2004.5 2500 Quad Cab LB 4x4 with stuff.
Old 02-01-2011, 09:56 AM
Resident Technician
Rep:1915
Sorry guys, but it's a bit more involved than that because the wiring for the fuel injectors is built into the gasket. You have to be really careful tightening down the nuts that hold on the injector connectors because they're really easy to overtighten and damage the injector. Try tightening the cover bolts, cleaning the engine and driving it a few days to see if the leak reappears before you replace the gasket.
CYLINDER HEAD COVER GASKET
1.Clean oil from cylinder head cover gasket
2.Inspect cylinder head cover gasket for cuts or damage. Replace if damaged.
3.Place cylinder head cover gasket on top of rocker housing (2).
4.Install injector solenoid nuts (1) at injectors. Tighten to 1.25 Nm ( 11 in. lbs. ).
5.Connect injector harness connectors (3) at cylinder head cover gasket.
Old 02-01-2011, 09:29 PM
Rep:93
Good stuff brother.. I didn't realize they had injector wiring interlaced!
Scott
Old 02-01-2011, 09:35 PM
Yeah, I'd see how tight the cover is first before you tear into it.
