plenum gasket location? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-15-2011, 06:25 PM
jaydubbz1019 jaydubbz1019 is offline
Vehicle: 1999 ram 2500
Color: met. red pearl
jaydubbz1019 is on a distinguished road
Send a message via Yahoo to jaydubbz1019
Default plenum gasket location?
i keep hearing that if i'm lossing power i should check this gasket to see if its leaking how do i do this and how would i go about changing it?
Old 01-16-2011, 03:13 PM
To see if you have a issue , remove the air cleaner assembly from the throttle body . With the engine off , open up the throttle . With a flashlight peer down the throat of the t-body and look at the floor of the intake . Do you see any oil on the floor . If so , the gasket has failed . The plate the needs to be serviced is on the bottom side of the intake manifold requiring you to remove the intake manifold . Chrysler does sell a kit for doing this . It comes with the updated parts and hardware . Check out our vendor http://www.moparonlineparts.com/ for any parts needed . They sell factory parts at a very discounted rate .
Old 01-17-2011, 12:56 PM
mowery33 mowery33 is offline
Vehicle: 1998 Dodge Ram
mowery33 is on a distinguished road
take care in removing the intake manifold bolts, especially the front ones, I've heard that they have a tendency to break (like two of mine did) when removing them, If I were you, and if I had the time, i would soak the bolts in some penatrating oil (PB Blaster is a good one) overnight just to loosen those guys up; this could save you a lot of time and headache.
