Bang In Reverse Noise And Hard Shift - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 01-16-2011, 12:09 AM
BIUBigPimpin BIUBigPimpin is offline
Vehicle: 2007 Dodge Ram 1500
Color: XR
BIUBigPimpin is on a distinguished road
Exclamation Bang In Reverse Noise And Hard Shift
I hope since I am new I will get a better response than the last gentleman that Had this same problem a few months back. I own a 2007 Dodge Ram 1500 4x4 1500 Slt Big Horn 5.7 hemi. 43,000 miles The reason i got the truck is so I could tell everyone MOPAR OR NO CAR. I am getting a noise (other than the eletric motor shifting) when I take my truck out of park and put it in reverse and it shifts really hard. Going down the road no problem and driving in the city start and stop the same runs great. 4x4 works fine the only thing is when I shift from park to reverse or pass reverse to drive there is a small pause before it goes in to gear and it goes in really hard. I will move the shifter back and forth a few times and it will improve some times but not always. Please Help with info. Thanks
Old 01-16-2011, 12:57 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Have you owned the truck since it was new? If you have, when was the last time the trans was serviced? How many miles has it got? What color is the trans fluid? How does it smell?
How about stopping by the Newbie area and introducing yourself.
Brian:
Old 01-16-2011, 01:02 AM
Color: XR
No got the truck used at 39,000. The fluid looks to be no more than maybe 10,000 miles old and smells sweet like out the bottle
Old 01-16-2011, 01:08 AM
Color: RootBeer
Rep:1287
With those kind of miles the fluid should still be in good shape, BUT, it should not smell brand new either. Does that make any sense?
If you're not real comfortable with working on transmissions, I'd suggest a stop by Aamco or the dealer. Did you get a warranty when you bought it?
Brian:
Old 01-16-2011, 01:12 AM
raceram9's Avatar
raceram9 raceram9 is offline
Vehicle: 07 Flame Red QC
Trim Level: Sport-R/T
Rep:51
raceram9 will become famous soon enough
Do you let the truck idle down before you shift it in to reverse or any other gear for that matter? My 07 dose the same thing unless i let it idle down a bit first i'll bet thats the problem let it idle down to about 800 rpms then shift it and tell us what it dose
2007 RAM QC FLAME RED,20s, 3.92 rear Vararam CAI, Cherrybomb vortex mufflers dumped out in front of rear tires, Superchips Cortex, R/T badges on grill and tailgate custom designed stripes and hood vinyl.....and more to come
Old 01-16-2011, 01:31 AM
Color: XR
My truck idles around 600-700 and it does not matter if it is that low it still does it and the fluid shows some wear but it not like it has never been changed since it was new. It still has a sweet smell and is red in color. I have a 150,000 mile warranty and can take it in any time but just trying to get a idea if I am not the only one with this problem and what it may be. I even allow time to let the shift motor fully put the trans in gear before letting off the brake. It also does not matter if the truck is already hot or not. Fluid level is in between the marks also.
Old 01-16-2011, 01:36 AM
Color: RootBeer
Rep:1287
It definitely should not be banging into any gear. Thanks for answering my questions.
Brian:
Old 01-16-2011, 02:55 AM
inkdemon's Avatar
inkdemon inkdemon is offline
Vehicle: 2015 Dodge 1500
Color: Vivid black
Rep:37
inkdemon is on a distinguished road
Send a message via AIM to inkdemon Send a message via Yahoo to inkdemon
check your universal joints on the driveshaft. Crawl under neath and see if you have any play.
Old 07-11-2015, 11:22 PM
pitucho10 pitucho10 is offline
Vehicle: 2008 RAM 1500
Color: grey
pitucho10 is on a distinguished road
Having the same issue with my 08 RAM 1500. Did this get solved?
Old 07-12-2015, 12:17 AM
striker2237's Avatar
striker2237 striker2237 is offline
Vehicle: 2003 Ram Laramie 4x4 3.55 LSD
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver
Rep:185
striker2237 has a spectacular aura aboutstriker2237 has a spectacular aura about
This, you would be surprised how much even minor play in a joint can bang around.
Mods: OEM tonneau cover+bug deflector+bedliner+floormats+hitch light+fuel door, Stubby antenna, 900CA AGM battery, Silverstar lights, Front window tint, Cabin filter, Bilstein 4600s, Kicker stage 1, Rear wheel liners, Mopar valve covers+breather, Pacesetter wrapped headers, Custom midpipe, Magnaflow X-pipe+custom axleback, SSBC front brakes+Powerstop rear, Moog front suspension+hubs, Maval custom rack, Borgeson steering shaft, Stainless steel brake lines, Hellwig front/rear sway bars, Poly bushings, Custom springs, Hydroboost
