Old 01-16-2011, 12:30 PM
rgnbull1227's Avatar
rgnbull1227 rgnbull1227 is offline
Vehicle: 2006 Dodge Ram Mega
Rep:104
rgnbull1227 will become famous soon enoughrgnbull1227 will become famous soon enough
Default 37's rubbing
Ok. So I rotated the 37X13.5X17 Toyo Open Country M/T on the mega cab yesterday. Now the fronts are rubbing when turning the wheel. Guess the fronts were worn down a bit. Should I go with 35's now? Will that stop the rubbing?
Old 01-16-2011, 01:12 PM
Are the offset between the front and rear rims the same ? Did you experience this when you first installed the tire/wheel combination ?
iRESQu iRESQu is offline
Rep:2217
Where are you rubbing at?
Old 01-16-2011, 01:47 PM
Is the wheel offset different on the wheels that were on the front??? Where is the rub?
That is weird!
