Old 01-16-2011, 12:43 PM
jdRAM88 jdRAM88 is offline
Vehicle: 2010 Ram 1500
Color: Inferno red
Rep:68
jdRAM88 will become famous soon enough
Default well ...its happening
well ive read about it and dreaded it but im starting to have FOB problems im going to make an apointment with the dealer this week but does any one know the actual cause of the problem? is it a big fix or a simple one? any one who has an answer would be great thanks !!
Old 01-16-2011, 12:45 PM
What is the FOB doing? Is it a basic FOB? Do only certain FOB functions work?
What the FOB is wrong with it?
Old 01-16-2011, 12:50 PM
Color: Inferno red
Rep:68
well.. for the most part its not unlocking or slow to unlock .... and the remote start is the same way
Old 01-16-2011, 12:53 PM
So there's a delay and it won't work from time to time, right? Have you tried it at different ranges or is this intermittent no matter how close or far you are from the truck?
I wonder if it's just the battery. We used to lengthen the receiver antenna on cars to get a bit more range. Obviously this worked but if the battery is getting low or there's a problem with the contacts or the transmitter chip, range is not the issue.
Old 01-16-2011, 01:55 PM
BobzRam BobzRam is offline
Rep:74
BobzRam will become famous soon enough
Maddog is right. I work with RF all the time. Basically all the fob is, is a small radio (RF) transmitter that sends a code to your truck (via its receiver) and tells it what to do. Key fob transmitters are very low power and are very range limited. They are also affected more by environmental factors. Certain fobs have been found to not work at all in an RF "noisy" area where they are easily overpowered by other sources. On top of this, being that they need a good fresh battery to operate at there best, it is easy for them to decrease in performance. Most people keep keys in there pockets or handbags where the buttons on the key fob are accidentally being pressed. Each time they are activated it eats up battery power, so even a relatively new fob may fail at what seems to be an early time.
Old 01-16-2011, 02:00 PM
Plus , I just changed out the batteries in mine and found that the contacts were loose fitting . I tightened them up and it works great now . I think the batteries were fine .
Old 01-16-2011, 05:33 PM
Color: Inferno red
Rep:68
that could be whats wrong with it.. but i can be standing right next to my truck and it wont work.. soo the battery must be really bad
Old 01-16-2011, 08:22 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
i have had my truck for 7 months with no problem with mine
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 01-16-2011, 08:42 PM
Ramathorne Ramathorne is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Color: Deep Water Blue Pearl
Rep:48
Ramathorne is on a distinguished road
Mine is starting to act up as well
Old 01-16-2011, 08:56 PM
jrwabw jrwabw is offline
Vehicle: 2010 Dodge Ram HEMI Crew Sport
Trim Level: 5.7 HEMI Sport
Color: Candy corn :)
Rep:151
jrwabw has a spectacular aura aboutjrwabw has a spectacular aura about
same here I work at a dodge dealer in the collision center. i will ask my buddy in service about it tommorow see how big of a problem it is and how many he has seen
