Old 01-19-2011, 01:03 PM
Butter's Avatar
Butter Butter is offline
Vehicle: 2010 Ram 1500 4x4 RC/SB
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
Originally Posted by RamTex View Post
I think he means the actual car battery not too sure but thats what i got from it.
It's the battery and contacts in the key fob that I was referring to.
Originally Posted by jdRAM88 View Post
how do you change the batteries and check the contacts?
You have to open up the key fob. I removed the key from the fob and used a small flat head screw driver to pry it apart, it just unsnaps into two pieces. Remove the button pad and you will see the battery and contacts. There are three prongs that make contact with the battery, the two that are on each side of the battery were fine, I did slightly and very gently lift the third contact that touches the center of the battery to make sure it was tight.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 01-19-2011, 01:34 PM
Shoua Shoua is offline
Vehicle: 2007 Ram 1500 Quad Cab
Shoua is on a distinguished road
My truck is about a 11months old now and noticed my key fob was acting up after 3months I ended up switching to the other fob and it has lasted until about a month ago, this last month has been weird, I will go a week where I have to press the button about a 100 times before it locks or and unlocks and then there will be a few days when it is completely fine, its driving me nuts, I think I am going to have the dealer look at it when they replace my cracking leather or i mean leather trimmed vinyl seat!
Old 01-20-2011, 12:34 AM
Hustleman Hustleman is offline
Vehicle: 2010 Dodge Ram 1500 Crew 2WD
Trim Level: SLT (Lonestar)
Color: Austin Tan
Hustleman is on a distinguished road
Like Butter said, just take the key fob apart and clean the contacts with an eraser. Also replace the battery and you should be good. I had every problem described above. Since I did this 6 months ago, all has worked flawless!
Old 01-20-2011, 06:23 PM
2010 trx4 hemi power's Avatar
2010 trx4 hemi power 2010 trx4 hemi power is offline
Vehicle: 2010 RAM
Trim Level: TRX4 Quad Cab
Color: Charcoal Metalic
2010 trx4 hemi power is on a distinguished road
Mark mine down also, its just now strating messing up
