Transmission problems - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 01-16-2011, 08:01 PM
aftershokk86's Avatar
aftershokk86 aftershokk86 is offline
Vehicle: 01 ram 1500 ext cab
aftershokk86 is on a distinguished road
Default Transmission problems
Started not wanting to shift out of first gear(in D) would get to redline at about 30mph, shifter was real loose.
dropped pan, replaced gov pressure sensor and solenoid(bought a od and lockup solenoid as well but didnt have time and was kind of intimidated to remove the valve body in the dirt, so i didnt replace it.) new fluid and filter.
now the shifter is tight like it used to be,(isnt slipping from d to n or 2) up shifts smoothly, downshifts smoothly.
Now my problem is when im at a complete stop, say going from reverse to drive, it takes a couple seconds to engage in gear, if i get on the gas and its not in gear yet, itll bang in gear and go, but if i wait a couple seconds its smoothe?
also if i let off the gas, use the brake,like slowing down for a right turn, and get back on the gas it seems like disengages the gear as if i was at a stop, and bangs back into gear. if i coast around the corner let off brake, give it a couple seconds and get back on gas, its smooth?
any ideas?
01Ram: infinity reference 6x9's/5.25's|kicker 12cvt|400w4channelamp|2500wmonoamp|
Old 01-18-2011, 01:39 AM
squintay's Avatar
squintay squintay is offline
Vehicle: 1999 dodge ram 1500
Color: green
squintay is on a distinguished road
check ur kick down cable that goes from ur throtel body. did u have any metal flakes in the trans oil, i had shif problems in he summer and did a rebuild found out i burnt ot 2nd gear . it was going from 1st to 3rd i also put a shift kit in it (its an automatic) for pulling trailers and make it last longer
MOPAR: Move Over, People Are Racing, Mostly Over Powered And Respected.
Old 01-19-2011, 09:49 PM
what shift kit you put in? im bought this truck so i could pull my yota(trailer and truck maybe 6k loaded for camping the whole weekend)
Old 01-19-2011, 10:14 PM
squintay's Avatar
Color: green
i dont remember the name but it was just a basic towing shift kit for a automatic trans. ur local tanny shop should be able to help u. it cost me 100$ and my friend who owns the shop installed it. ill c it i can find out the make
