United Radio
Old 01-16-2011, 08:42 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Thumbs up Have a Spray in Liner or Want One? Read this
If you don't have a spray in liner but want one have them remove all plugs before they spray the bed to save yourself a PITA if you ever want to remove those plugs. Don't forget to put the plugs back in when the liner is cured so they don't stick to the liner.
For those that have a spray in liner already, here's the procedure for removing the plugs without making a mess of your liner like I did.
First we have a shot of the plug before removal.
This is what happens when you do it wrong, like I did.
To avoid a messy appearance use a very sharp knife or razor blade. Slice through just the liner, not the plug. Pull some of the liner material away and begin slicing until the whole plug is exposed. If done right like I did on the second plug, you will get a nice clean opening with nice edges on the liner. It will look like this.
Brian:
Old 01-16-2011, 08:59 PM
iRESQu iRESQu is offline
Rep:2217
Thank you, Brian as I want the spray in and we were contemplating that. One other question, what did you do with the top of your bed, along the edges? If we remove the plastic pieces then you can see holes in the metal where the plastic was adhered to my truck through.
Old 01-16-2011, 09:00 PM
USMCRONIN1's Avatar
USMCRONIN1 USMCRONIN1 is offline
Vehicle: 08 Ram 1500 4x4
Trim Level: Big Horn Edition
Color: Electric Blue Pearlcoat
Rep:100
USMCRONIN1 will become famous soon enoughUSMCRONIN1 will become famous soon enough
Yeah, I had this issue the other day when I went to run the antenna cable for my new CB...
Iraqi War Veteran Four Times Over, and I have a concealed carry permit....any questions?
Old 01-16-2011, 09:14 PM
Color: RootBeer
Rep:1287
Paris,
The liner is what is called "under the rail". It does go over the top of the front which is a good thing.
The side rail caps should be removed for exactly the reason you mentioned, the holes.
Brian:
Old 01-16-2011, 09:22 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
i want a spray in liner and i want it over the rails cuz the cheap plastic rails suck
Old 01-16-2011, 09:25 PM
Color: RootBeer
Rep:1287
It can be done, but you'll have to fill in the holes in the rail left after you remove the caps, before they spray it.
Brian:
Old 01-16-2011, 11:00 PM
BigSwede's Avatar
BigSwede BigSwede is offline
Vehicle: 2011 Ram Sport Crew Cab
Rep:371
BigSwede is just really niceBigSwede is just really niceBigSwede is just really niceBigSwede is just really nice
The place that'll do my spray in liner is a Linex place. They remove all the plugs and the bed bolts before they coat. Then they spray the bed. Before re-installation, they coat the tops of the bolts. When they are done, the plugs go back in their normal places without being painted in.
They do good prices as well...thank god
-Frank
Old 01-17-2011, 01:28 AM
Good info, Brian. I am wanting to do a liner soon.
Old 01-17-2011, 09:17 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Interesting... I'll definitely keep that in mind when spraying mine on.
Old 01-17-2011, 12:49 PM
Mcbride's Avatar
Mcbride Mcbride is offline
Vehicle: 2011 ram 1500 Crewcab 4x4
Trim Level: Sport/SLT
Rep:13
Mcbride is on a distinguished road
Good tips, thanks RootBeer.
Its not a mistake that mans best friend cannot talk.
