Old 02-22-2013, 12:43 AM
al57king al57king is offline
Vehicle: 2003 Dodge Ram 1500 4.7
Color: Blue
al57king is on a distinguished road
Smile
I am so thankful i came upon this post. I was having the same exact issue with my truck and after changing the ignition switch, cam and crank sensor, TPI and IAC I was scratching my head. 2 weeks ago I had a code that directed me to #7 cylinder not firing. I replace the coil at that time. So It never occured to me that the new coil could be the culprit till I read this post. Needless to say, I went straight out to the truck and disconnected the new coil and bingo truck started right up like normal. I replaced it and I am one happy camper today. Thanks to this post!
Old 02-22-2013, 12:53 AM
Color: Blue
Default Many Thanks
Originally Posted by trvcampbe View Post
Its Alive!!! This makes no sense..I replaced a coil last week with a Standard Ignition..This morning i was unpluging one at a time and trying to start it..When i got to the new one and unplugged it,the truck runs now..Does the ignition coils have to be programed to the PCM?
I was so glad to come upon this thread. I had the exact same problem with my truck. Funny cause 2 weeks ago I had a problem with the truck and has a code that directed me to the #7 cylinder. I changed the coil on 7 and was back in action. But just the other day the truck died and was almost impossible to start and when it did it ran fine untill you gave it any large acceleration it would stall and die. After replacing the igniton coil, both cam and crank sensors, TPI and IAC, I was scratching my head. It never occured to me that the new coil could have gone bad, but after reading this thread, went straight to my truck and disconnected #7 coil and bingo, started right up. Needless to say i ran out and replaced it and I'm one happy camper thanks to this thread....
Old 02-20-2014, 01:22 PM
Shredder1212 Shredder1212 is offline
Vehicle: 1997 dodge ram 1500
Color: Brown
Shredder1212 is on a distinguished road
Default Same problem but coils number 7???? What?
I have my dodge ram that will start then die witching a few seconds. I read this forum and found people who replaced the coil on cylinder 7 and fixed it? What are they talking about?
Old 02-20-2014, 01:41 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The 3rd Gen Trucks have independent coils for each cylinder (4.7). The Older trucks had one coil that supplied spark to all of the cylinders.
On top of each cylinder there is a coil. Under the coil is the spark plug. Try unplugging #7 and starting the truck with it unplugged.
Old 02-20-2014, 01:45 PM
Color: Brown
Thank you I see what you're talking about now!
Old 02-21-2014, 09:45 AM
TooPoorForHemi's Avatar
TooPoorForHemi TooPoorForHemi is offline
TooPoorForHemi is on a distinguished road
Did you ever drain the power out of the system by disconnect in the positive and negative terminal?
