Old 01-16-2011, 09:54 PM
Turk999 Turk999 is offline
Turk999 is on a distinguished road
Default Both Cooling and Heating
I have an 02 1500 4x4. The problem is that when I use the A/C the air does not get cold until I'm moving. Its the same with the heat. I have to be moving for anything to work right. There is plenty of air coming out, just not hot or cold till I'm moving.
Old 01-17-2011, 09:36 AM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
Cold air only when moving...condensor fan is shot...causing freeze up when no air flow. Same thing happened to my 03. $74 for the complete shroud and fan from ebay. About 1 hour to replace, but you have to cut the shroud. Search the forums and you will find all the info you need.
Not sure about the heat part.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 01-17-2011, 09:58 AM
Rep:1890
The heat could be a flow problem such as a weak water pump.
Old 01-17-2011, 10:35 AM
But it all started at the same time.
Old 01-17-2011, 10:40 AM
Rep:1890
Does this happen in fresh air mode may have, recirc, or both? I'm starting to think you have a blend door problem.
Old 01-17-2011, 10:43 AM
Both on all settings. No matter if its on defrost or on the floor. The air changes locations with no problem. There is even times that if I do stop it works fine but most of the time it doesn't.
Old 01-17-2011, 10:49 AM
Rep:1890
I'd get the mode/blend/ricirc doors checked out.
Old 01-17-2011, 10:51 AM
ok thanks i'll check that out and let everyone know
Old 01-17-2011, 01:50 PM
latitud's Avatar
Rep:71
Heat only when moving is strange...very strange...let us know what you find. I wouldnt think a blend door problem since you are not changing the setting or position from stop to moving, unless the air blowing through when moving is actually moving the blend door.
I experienced the no cold air when stopped, but fine when moving. Check to see that your condensor fan is working when sitting still and the a/c is on. If the a/c continually turns on and off and on and off...and the fan is not moving..then that is ur problem for the cold air only working when moving. Good luck.
Old 01-23-2011, 10:58 AM
Wow do I fell dumb....... I checked the antifreeze level to find it was low. I took almost a gal of it. Well after I filled that, the heater now seems to be working great. Now just to figure out the A/C. But what I have noticed. Is the the condenser fan seems to be running all the time. Even when the A/C off. Now its been to cold to really sit there and trouble shoot but is that normal for the fan to be running like that?
