99 1500 5.9 Overdrive Lock-up Problem. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-17-2011, 07:33 AM
delineated's Avatar
delineated delineated is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT Laramie
delineated is on a distinguished road
Default 99 1500 5.9 Overdrive Lock-up Problem.
Hello. I have a 99 5.9 with a overdrive issue. Was out one Saturday driving and noticed that I lost overdrive. Drove it home, let it sit till the next day. Had to get to work so drove it to work, when I left the house the truck would shift into OD fine. I drove on the highway for a little bit and when I got off it would no longer go back into overdrive. Same thing when I left. Seems like it will shift into overdrive 1 or 2 times and the next time it downshifts it will not upshift back into overdrive or lock up. Now I put the truck into the shop, had the trans completely rebuilt, he said he changed some solenoids, and I took it to the dealer to have it reflashed. Now the truck shifts like a brand new trans, except no overdrive lock-up. Same thing, drive for a few miles, then none. It will shift into 4th if I turn off the o/d switch I think. I know it acts different if I turn it off. Even my mechanic is scratching his head. What a nightmare. Thanks for reading.
Old 01-17-2011, 11:33 AM
Resident Technician
Rep:1915
It's going into overdrive with the switch in the off position? Have you had the TCM scanned? It also sounds like you may have a fluid overheating issue which will inhibit a shift into overdrive.
Old 01-17-2011, 02:17 PM
delineated's Avatar
No overdrive but it feels like it has one more gear if I leave the od switch off. I am taking it back to the mechanic today after work and he wants to change the computer out....I already took it to the dealer and had it flashed to the newest thing. One thing I havent mentioned is that the last battery that was in there leaked all over the wiring harness underneath it. When I bought it there was a CEL and had to take it in to get that fixed. It was a frayed wire underneath the battery. So we think it has something to do with that. I just dont understand why it would shift when I first take it out. Thanks for your reply.
Old 01-19-2011, 06:15 PM
delineated's Avatar
Turned out to be the, "Battery Temp Sensor"... Now for the water pump!
