Place your Ad Here!
Old 01-17-2011, 12:09 PM
cjay cjay is offline
Vehicle: 2011 Ram 1500 Crew-cab
cjay is on a distinguished road
Default add Gas tank Capacity
I have the 25 (I think) gallon tank in my new truck. I need more gas (not diesel) capacity. What could my options be? I would rather not do a transfer tank, but if that is the only option… Thanks in advance. Jay
Old 01-17-2011, 12:17 PM
Good question. There are aftermarket tank makers that claim to be able to add 7 - 10 gallons of capacity and be able to fit the tank in the stock locations. I don't know that anyone has one for the 2011 yet but it may be worth a Google or two.
A transfer tank is definitely an option and there may also be small auxiliary tanks that you could add a second filler neck, cap and transfer pump to.
Old 01-17-2011, 01:23 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
You should have 26 Gallon standard, and there is a optional 32 Gallon tank. I dont see why you couldnt do a OEM swap from the 26 to 32. But it maybe easier said than done.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 01-17-2011, 02:04 PM
Jason Rose Jason Rose is offline
Vehicle: 2009 Dodge Ram Laramie
Color: Black/silver
Rep:51
Jason Rose will become famous soon enough
My truck has the "optional" 32 gallon tank. It came that way from the factory. (you can see what truck it is in my description). I'd bet it's not cheap to buy that 32 gallon tank but I'd assume all the "guts" just swap from one to the other. I'd guess there is room under the bed already there for the larger tank so nothing would have to be moved.
Old 01-17-2011, 08:16 PM
Ram15002ndgen's Avatar
Ram15002ndgen Ram15002ndgen is offline
Vehicle: 97 Ram 1500
Trim Level: Laramie SLT
Rep:55
Ram15002ndgen will become famous soon enough
It should be do-able. I have read about guys doing it in the 2nd gens. Same situation from 26 to 32. The space is already there since the tanks are just a little bit longer and will bolt right up.
www.beatcraigslist.com - for posting dangers & secrets
Old 01-18-2011, 04:00 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
i saw an additional tank in a magazine once that outs on the other side of the truck doubling your fuel capacity, there is just a hoes that runs from pone to the other. sorry was a long time ago so no names for you, but they are out there. not to sure if theyre there yet for the 2011 dodge
DODGE the father RAM the daughter!
Old 01-18-2011, 10:30 AM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:77
jmr will become famous soon enough
I've got the 32 gallon tank option too. To experiment I've had it where it showed 20 miles on the DTE indicator and it's never taken more than 28 gallons. When I filled it up it was literally to the top of the cap. I don't think it really holds 32 gallons it's more like 30 gallons maybe.
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 01-18-2011, 11:21 AM
Resident Technician
Rep:1915
It does but Rams are designed to read a bit less than what you actually have to prevent running out of fuel plus a 1/2 gallon or so that wont be useable.
Old 01-18-2011, 11:26 AM
BigSwede's Avatar
BigSwede BigSwede is offline
Vehicle: 2011 Ram Sport Crew Cab
Rep:371
BigSwede is just really niceBigSwede is just really niceBigSwede is just really niceBigSwede is just really nice
Check a used parts place. There's bound to be a wrecked ram with a 32 gal tank that you can swap in. The electronics (pump, etc) should be the same. Connections and mounting may be a bit different.
-Frank
Old 01-18-2011, 11:31 AM
Resident Technician
Rep:1915
The pump unit may not be the same. I'm showing 2 different part numbers but they don't say which is for which tank. The only way to be sure would be to check with the VIN of a truck that has the 32 gallon tank.
