Old 01-17-2011, 01:43 PM
cmatt4775 cmatt4775 is offline
Vehicle: 2010 Dodge Ram SLT
cmatt4775 is on a distinguished road
Default Off Road All Terrain Tires
I currently have stock 20's on my truck and am due for new tires and I was looking to put some off-road all terrain tires on i have a inch level kit on front and 1 inch on back which said I could fit 35's but I am really only looking for 29's or 33's. I am new to this so I am not sure of how to do the sizing could some one give me an ideal tire company model and size it would be greatly appreciated
Old 01-17-2011, 01:58 PM
GregRam1500's Avatar
GregRam1500 GregRam1500 is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Quad Cab Short Bed
GregRam1500 is on a distinguished road
I have 17's on my truck. I recently brought me 4 BFGoodrich All Terrain 265/70 BFGoodrich are good wear and great in winter. Depending how do you want for size of tires. Are you looking for better gas mileage, more power, and heavy duty (# ply)?
Old 01-17-2011, 02:01 PM
Nitto Terra Grapplers, Cooper ZEON LTZ's, Toyo Open Country M/T's, Mickey Thompsons...etc....
Lots of choices out there. 33's with the level kit will work but a 285 section width tire on stock rims will be the max to avoid rubbing at steering lock.
Old 01-17-2011, 02:23 PM
Would 33x12.50-20 Toyo Open Country MT work?
Old 01-17-2011, 09:51 PM
ScatPak07's Avatar
Rep:970
Your "leveling kit" isn't really one since your only up 1". You are pretty much looking at 33" tires tall. Only thing is if you are running stock rims you wont be able to get wider then 305. I know this because I had 305/55/20 tires on my 07 Ram, but I had a 2" lift (front and rear). Maddog may be right when he says 285, I forgot I had 2" of lift.
I am going to say that those tires will not fit, 33x12.5x20. You will be rubbing on the suspension components since you are basically running a stock set up
