Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 01-17-2011, 06:44 PM
magnumcharger magnumcharger is offline
Vehicle: 1996 Dodge Ram 4 x 4
Color: Red over silver
magnumcharger is on a distinguished road
Default Crazy Transmission problem!!! I'm baffled!!
My Ram has a most peculiar problem with it's transmission:
Driving with the cruise control on (and the overdrive off), travelling at 60mph, I hauled a loaded car trailer up a hill.
Suddenly the cruise kicked off and there was an adible BANG!
After that, when I stepped on the gas, I heard a sound similar to when you suck a milkshake through a straw and reach the bottom of the cup.
As well, the truck had no appreciable forward motion as I applied the pedal. I ended up stopping on the hill. I tried starting off again and found I had low gear - only - and I could VERY LIGHTLY apply the gas pedal and go forward. However, the truck would NOT upshift, and made that sucking sound (like a carb at WO). As I got to the top of the hill, I picked up speed and the truck upshifted. On a flat straight I managed to get it back up to speed....until I came to the next hill! Then it was back down to 5mph all the way up the hill.
Old 01-17-2011, 06:49 PM
I'm not sure myself , but the BANG doesn't sound good . I take it it's the original tranny ?
Old 01-17-2011, 08:51 PM
Yes it's the original transmission.
Two years ago, I had it repaired by an AAMCO Transmission shop when the third gear/reverse sprag was worn out (I think that was the problem!).
Other than that, it's worked great.
Old 01-17-2011, 08:52 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
With it idling in neutral, how's the fluid level? What color is it? How does it smell?
Brian:
Old 01-17-2011, 09:41 PM
First thing I did after it started acting strange was limp it to the closest gas station. I set the parking brake and put the transmission in neutral. I checked the fluid level, and it was right on the "hot" line. I had extra fluid onhand, but it didn't need any. And it didn't smell burned at all. Weird, huh?
The problems with the transmission are similar to how I would describe an older V8 missing it's kick-down linkage.
Old 01-17-2011, 09:45 PM
Color: RootBeer
Rep:1287
Unless you're comfortable tearing into a trans, it sound like trans shop time.
Brian:
