Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 01-18-2011, 02:05 AM
ewb's Avatar
ewb ewb is offline
Vehicle: 2013 dodge ram cc
Rep:171
ewb has a spectacular aura aboutewb has a spectacular aura about
Default Need help with backup camera and AVH-3200BT
I have an AVH-3200BT pioneer and the problem is with the backup camera. I hooked up the red wire to the backup light wire, grounded the black and the video to the stereo. Problem is the main screen is now a black screen that says "caution,screen images may appear revered" and a black screen. If I touch it it will go to the main screen but then right back to the black caution screen. Like its waiting for the picture and for me to put it in reverse. Its become the default screen. I have the polarity on BATTERY, but I have tried GROUND also. No different. thanks for the help guys.
Walter
Old 01-18-2011, 10:28 AM
Resident Technician
Rep:1915
When you say the backup wire, do you mean the white/red going directly to the lights themselves?
Old 01-19-2011, 12:55 AM
ewb's Avatar
ewb ewb is offline
Rep:171
Yes. What I am unsure of is that the techs at crutchfield told me the hot wire needed to be attached to a switched accessory instead of a constant hot from the 10 pin off of the trailer hitch attachment. I tried both ways but neither worked and I still got a black camera screen. What is weird is that now I am getting the camera to work when I am in drive or park and when I shift to reverse I get the regular radio or I should say the main screen. I called again to the techs at crutchfield and they told me it might be the pac so they are sending me another one.
Walter
