I have a squeek... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
Diesel Forums!
Dodge Caliber
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 01-18-2011, 08:34 AM
wedgeheaded's Avatar
wedgeheaded wedgeheaded is offline
Vehicle: 06 1500 QC 4x4
Rep:111
wedgeheaded will become famous soon enoughwedgeheaded will become famous soon enough
Default I have a squeek...
... and it'd driving me nuts. I added a set of running boards which are a huge help, but they are squeeking when the body flexes. These boards are 2x4 reinforced boxed extruded aluminum. Very solid and simple. They mount to an arm that attaches to the cab mounts and have a brace that attaches to the inner rocker. Would a dab of greese help, or maybe something else? My guess is you guys have been here did this. Any thoughts?
Old 01-18-2011, 09:16 AM
USMCRONIN1's Avatar
USMCRONIN1 USMCRONIN1 is offline
Vehicle: 08 Ram 1500 4x4
Trim Level: Big Horn Edition
Color: Electric Blue Pearlcoat
Rep:100
USMCRONIN1 will become famous soon enoughUSMCRONIN1 will become famous soon enough
I had the stock OEM step bars, and after a while they were squeaking at every little divet and hole in the road. Go through and double check, make sure everything is cranked down nice and tight, turns out one of my bolts was loose causing all the racket. Best of luck with it!
Iraqi War Veteran Four Times Over, and I have a concealed carry permit....any questions?
Old 01-18-2011, 09:58 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
^^^What he said^^^
When you find the culprit, add some thread locker or at least lock washers to all the connections to keep it from happening again. Good luck!
Old 01-20-2011, 12:35 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
Could be a broken weld, happen to a friend of mine.
Old 01-20-2011, 07:50 AM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Use a rubber/heavy foam 'gasket' between metal to metal connections.
