Old 01-18-2011, 09:35 AM
ScratchSoulja's Avatar
ScratchSoulja ScratchSoulja is offline
Vehicle: 2006 Dodge Ram 1500 SLT 4x4
ScratchSoulja is on a distinguished road
Default 40 inch tires? Need larger gears?
Trying to figure out if I put 40 inch tires on my truck with i need to change the gearing?? I have 3.92 gear ratio in there now.. I know i can do a 38X13.50 with no problem but I think i might want to go a little bigger.. Any ideas??
Old 01-18-2011, 09:39 AM
BigSwede's Avatar
BigSwede BigSwede is offline
Vehicle: 2011 Ram Sport Crew Cab
Rep:371
BigSwede is just really niceBigSwede is just really niceBigSwede is just really niceBigSwede is just really nice
If you don't re-gear, you'll lose all of your bottom end torque.
Post pics with whatever you decide on!
-Frank
Old 01-18-2011, 09:41 AM
RamTech RamTech is online now
Rep:1885
I'm thinking at least 4.56 gears or maybe even 4.88 or something in that neighborhood.
Old 01-18-2011, 11:51 AM
Yup...^^^^...So was I. Minimum 4.56's
Old 01-18-2011, 12:28 PM
Thanks for the info everyone.. Any suggestions on what kind of gears I should look into in the future?? I would like to put lockers in it eventually
Old 01-18-2011, 12:32 PM
Rep:1885
Brand wise, Richmond is a very good choice. I used them in my drag car for years without any problems.
Old 01-18-2011, 06:19 PM
Rammin's Avatar
Rammin Rammin is offline
Vehicle: '03 Dodge Ram 1500 2wd
Rep:44
Rammin is on a distinguished road
Do yourself a favor and get the lockers at the same time as the gears. The labor is what kills you when having your axles worked on so save yourself some money in the long run and get it all installed at the same time.
Old 01-18-2011, 09:58 PM
SUL7ENAZ's Avatar
SUL7ENAZ SUL7ENAZ is offline
Vehicle: 1999 Dodge Ram 1500 QuadCab
Color: blue
Rep:463
SUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of lightSUL7ENAZ is a glorious beacon of light
Everyone posted great advice. I agree.
SUL73NAZ
Old 01-19-2011, 02:12 PM
Yeah I was thinking of getting the lockers at the same time any suggestions on a locker to go with?? There are so many out there its hard to decide which one to get.. As far as labor goes I work at a dodge dealer so atleast i got the hook up here with service my buddy usually helps me out with the work..
Old 01-19-2011, 02:57 PM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
With 40 inch tire, I'd probably run 4:88s or 5:13s.
I'm sorry to tell you this, but I don't believe your front IFS will take the pounding from such a heavy tire, especially off road. I'v seen two such rams litterally blow thier front diffs to bits with just a 36 inch while off roading, and they were both unlocked. You'll be twisting front CV axles up like pretzels. Both trucks have since converted to solid front axles.
On a street only truck, they might survive.
I would do some research in forums where guys do a LOT of off roading and regularly run BIG tires. I could name them but don't want to get in trouble.
